Super cheap coplete gasket kit.. is it worth it??
Old Dec 2, 2009 | 12:59 PM
JDMDAtehbeast's Avatar
Default Super cheap coplete gasket kit.. is it worth it??
http://mizumoauto.com/product/view/id/319
what do you guys think??
Old Dec 3, 2009 | 07:39 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Super cheap coplete gasket kit.. is it worth it??
^no. youl regret it.
dont cheap on gaskets and bearings.....
Old Dec 3, 2009 | 08:11 AM
vtechjunkie's Avatar
I used a Yonaka gasket kit. $120, and it worked great!
Old Dec 3, 2009 | 08:48 AM
mouab18c1's Avatar
just go to Napa or Schucks if you want to cheap out on gaskets.
Old Dec 3, 2009 | 09:02 AM
well if i got it i definatly would not use the headgasket... but everything else like the valve cover, oil pan, and all the other smaller gaskets look like theyd be okay i mean there just rubber right you cant screw that up.. if i put them on with some rtv or something they should be fine right?? is there any one thats actualy bought a gasket kit from them??
Old Dec 3, 2009 | 05:40 PM
l337h4l's Avatar
cometic gasket is making full gasket kits and seals now
Old Dec 4, 2009 | 12:46 AM
ironcheftony's Avatar
ive used a couple of these cheaper gasket sets, even the headgasket, they work fine, no problems on oem rebuilds
Old Dec 7, 2009 | 06:04 PM
g2daturbo's Avatar
ive used them on a few stock rebuilds with no issues at all..done a few stock ls motors and did a gsr motor for my gf's car with 10k so far with no issues...!
Old Dec 9, 2009 | 01:00 PM
I think im going to go ahead and get it. and if anything if i dont like how the headgasket looks ill just order one. other than that it looks to me like they would be fine. thanks for the input guys.
Old Dec 9, 2009 | 05:23 PM
non-VTEC's Avatar
looks like a multi-layer steel head gasket....like oem....i would use it on a stock rebuild no problem......just make sure you test fit everything first.
TracerAcer2.2L
Jun 29, 2018 10:21 AM
Nicholas Bailey
Transmission & Drivetrain
May 24, 2016 01:35 PM
W O T
Mar 23, 2006 12:57 AM
RicedREX
Feb 9, 2003 09:31 AM
StinkyTofu
Mar 28, 2002 07:54 PM
