My b20 vtec build
hi Honda tech this is my first build Im wondering around how much power would it make if anyone has done it.b20 block with golden eagle block guard11.5.1 rs machine pistons stock pr4 rods arp rod bolts acl standard bearings. gsr b18c1 head skunk2 pro intake manifold 70mm tb arp head studs 2 layer head gasket with copper sealer with 440cc rc injectors and itr cams 98 spec Mugen headers 2 1/2 piping and Jdm Lsd b16 trans with clutch masters race disk and pressure plate...
why don't you check the threads that are constintley discussing b20vtec perhaps you'll find ur answer there better then bumping a 5 month old thread and wait
there is alot of b20vtec setup's i'm sure you'll find one that has the power u need
yeah, there are a BUNCH of builds that are similar to yours. But with your setup, maybe 210whp?? Get some better headers, maybe a nicer set of cams, tune and youll easily be at 225-235+whp. Like i said, the only thing I would change are those shitty megan headers. ITR Cams will be okay for now, but why not go bigger? (may i suggest Skunk2 Pro1s, pro2s, dont forget your valvesprings and retainers) And with a big tube hytech replica, youll be much more happy!
EK FLY
Feb 7, 2007 10:43 PM
