First GSR build oil leaking out badly(Video)
This my first build and when the car about to start a lot oil coming out from breather chamber
and the transmission area what you guy think the problem is?? you can see in the video the car start for little bit 0:29 then oil coming out and die HELP me find the problem PLEASE!!!!!
http://www.youtube.com/watch?v=Ydhwyw1XjHg
Yep, old oil filter gasket or you installed your HG (headgasket) backwards/upside down. See where it coming from on the backside....if its right under the intake manifold by the transmission it very well could be the HG. If it is installed incorrectly you can usually see the piece of it hanging out the backside by about 10mm
I think i know exaclty what that is man, happened to me before too, i had the gasket upside down, everything lines up except for one oil passage on the back of the block, when i turned it on, oil poured all the way out, i noticed i put the gasket upside down when i took the head off
B16CivicEX
May 30, 2006 03:15 PM
