F/S Honda Part Out b20 stroker,turbokit,s300,b16 built head TN
PRICES LOWERED!!!!!
Ok guys im parting out an entire build all parts. engine, head etc have less than 5k miles and are in good working condition unless stated. Email me at Finalldt@aol.com or txt 865-696-2434. Knoxville, TN 37920
$1000 obo
B20 stroker engine 2.2 liter, Eagle stroker crank, eagle rods, je pistons, arp head studs, used cometic hg. Engine still runs but needs refreshened, compression is down in cylinder 4 at 125, rest are 195, pistons are at an 8.5 to 1. Recommend rering and rehoning cylinders and checking all bearings. Should cost around 400 at a machine shop.
$900 obo
B16 head with Brian Crower, springs, retainers, valves, stage2 turbo cams, good lma's. Head is fully assembled and in perfect condition. Head will include vtec solenoid, valve cover, intake manifold bare, hondata plastic manifold spacer gasket, golden eagle vtec kit with sandwich plate and oil lines. no dizzy, no tb.
$750 obo
Full B series Turbo Kit. Includes t3/t4 Turbo, Full 304 stainless turbo manifold, Tial 38mm wastegate w/ 10 lb spring, can swap in 7.4 lb spring, Wastegate dump pipe, Full 3 in stainless down pipe w/ o2 bungs for primary o2 and wideband. Short intake and filter, Oil feed line, oil return line and flange. Front mount intercooler with complete intercooler piping setup, including couplers and tbolts. All for an integra dc body and requires minimal trimming of bumper and mounts easily. Comes with choice of evo mr metal bov or turbo xs rfl. Evo bov is quiet, turbo xs is loud. Includes all bolts/hardware and gaskets.
Sold
Mishimoto Integra radiator full size, includes slimline fan already installed, includes mishimoto radiator cap.
Sold
P28 Ecu obd1 with Hondata s300, includes all cables and software cd.
Sold
Hasport motor mount set, includes all 3 mounts and bolts, fits 94-01 integra or swaps b series into 92-95 civic, or 93-97 delsol.
$300 obo
Competition stage 5 clutch kit, includes disc and pressure plate. Very streetable clutch kit light pedal application and very little chatter. Also includes lightweight flywheel, not positive on brand but pretty sure its fidanza.
$150 obo
Moroso Drag Oil pan 5.5 qt capacity comes with welded on bungs for oil return drain, has internal baffle plates for oil control in turns and acceleration and a kicked out sump.
$50 obo
Weapon R oil/coolant catch can.
$50 obo
HKS Black Turbo Timer
Sold
Skunk 2 Racing Strut bars, Front and rear
Sold
Skunk 2 Lower tie brace
Sold
Skunk 2 Lower control arms Gunmetal
$100
Omni Power Camber kit 92-95 civic 94-01 teg Brand new
$125 obo
Skunk 2 Camber Kit 92-95 Civic 94-01 teg Used
$50 obo
Momo Steering wheel hub adapter BNIB 88-91 civic PN#4905
$50 obo
Sparco Steering wheel hub adapter BNIB 92-96 Prelude PN#01502083
Sold
RC 440 CC injectors High Impedance no resistor box required
$75 obo
P28 Auto ecu virgin, good condition
$125 obo
p28 Manual ecu virigin, good condition
$1000 obo
$900 obo
$750 obo
Sold
Sold
Sold
$300 obo
$150 obo
$50 obo
$50 obo
Sold
Sold
Sold
$100
$125 obo
$50 obo
$50 obo
Sold
$75 obo
$125 obo
Bump
Will work with price on engine and head if anyones interested
Got a lot of interest in all the other parts so if anyones looking for a killer deal on a stroker or a fully built b16 head let me know. Thanks.
Also if the rings in the stroker have people concerned I can send it to the machine shop and have it done in a couple days. Gauranteed perfect bottom end new rings/bearings, whatever is needed for 1900.
how much power did that turbo kit make??
im interested....is the price firm....
ho much for the whole kit and the 440's if i drove from ohio and came and got it>?
The car was making around 400 hp but I couldnt tell you for sure as it never saw the dyno. It would obviously vary depending on your engine build and compression but the whole setup should make well over 400 on 18-20 lbs, injectors is about the only thing that holds it back. What exactly are you interested in. Just the turbo kit or kit and engine and everything? Let me know if so I can make you a deal. Where abouts are you in OH? I used to live up in toledo, still got friends up there.
Bump for sold items.
s300 and injectors currently sold
radiator and fan sold
Mounts pending payment going through.
Bout to text you back on strut bars man sorry been busy with everything.
Hondata s300 and injectors sold
Mishimoto radiator and fan sold
Skunk2 strut bars sold
Skunk2 rear tie bar sold
BUMP for seller, I saw all parts in person and picked up all the skunk2 parts. Let me know if you wanna sell the ****, tailights, and exhaust! Also you you have an stock radiator laying around or B series axles?
Thanks
Thanks
Will Sell all remaining items for 3100 plus shipping and paypal fees.
Thats fully Built Long Block,clutch flywheel setup, oil pan, golden eagle lsvtec kit and turbo kit all for 3100. Thanks.
Not ready to come off the shift **** and tail lights right now. Will let you know if anything changes. And no stock rad or axles sorry. Thanks.
Hey are you trying to get the car to run? I can trade you my stock gsr parts if you need stuff, tailights, suspension, ****, etc that way you can sell the car. Let me know
Yeah I could definitely use the stock suspension parts, i meant to ask you when you were here but forgot. I am trying to put the car back to stock, ive got the stock ls motor for it. Just having a hard time selling the engine and turbo kit right now.
