need help with my alignment on lowered crx si
Old Nov 30, 2009 | 05:53 PM
michael-crxsi's Avatar
Default need help with my alignment on lowered crx si
i just go my alignment since my car had been lowered. they told me i need to buy adjustable ball joints for my front. im a little confused if i should get the ball joint or if a camber kit is what i need. im trying to spend little cash and ive seen the ball joint are cheaper but they all have different adjustment ranges and i dont know what i need.
Old Nov 30, 2009 | 05:56 PM
danimin's Avatar
Default Re: need help with my alignment on lowered crx si
i would imagine a camber kit is needed, but im a noob
Old Nov 30, 2009 | 06:13 PM
Tyson's Avatar
your toe is fine and thats all that matters. your camber is high, but not needed to be adjusted. so is your cross caster, but thats not really adjustable anyway.
whats more important is whats up with just the front alignment?! a 2 wheel alignment is for trucks... you got rear wheels that need attention too. go back and get the rear aligned.
Old Nov 30, 2009 | 06:42 PM
will the camber hurt my tires? i have no clue why they didnt give me a chart for the rear
Old Nov 30, 2009 | 06:50 PM
dacrxguy's Avatar
camber is a bit to high for me about a half inch where pulling starts to accour i hope that they aligned the rear if not the thrust angle can be off (rear alignment affects the front) and the thrust angle will cause drive-ability problems.
As for the adjustable ball joints they are talking about adjustable upper control arms
Old Nov 30, 2009 | 06:51 PM
Tyson's Avatar
no, camber does not. go back and get the rears done. its more important than worrying about camber.
Old Nov 30, 2009 | 06:53 PM
dacrxguy's Avatar
so if a car pulls should i worry about camber
Old Nov 30, 2009 | 07:03 PM
ive searched adjustable ball joints and that seems like what they meant
http://www.circletracksupply.com/pro...?productid=578
ive also looked at this one on ebay
http://cgi.ebay.com/ebaymotors/88-95...Q5fAccessories
i like the price of the ebay ones better
Old Nov 30, 2009 | 07:06 PM
88Hatchy's Avatar
don't waste money on comber correction kits
Old Nov 30, 2009 | 07:37 PM
sxysweed's Avatar
If you want to correct camber, do it the right way: Skunk2 Upper Arms.
You don't need to correct it though. What you need is the toe fixed and a rear alignment.
Old Nov 30, 2009 | 07:45 PM
the toe is perfect now. i think you read the chart wrong
Old Nov 30, 2009 | 08:21 PM
johnnyonth3spot's Avatar
Dont worry about the camber, listen to tyson he knows his ****.
Old Nov 30, 2009 | 08:43 PM
vtec_ef8's Avatar
if i were you i would worry about the camber with the camber 3.0 on the left and 2.5 on the right your going to get bad tire wear even if the toe is set to 0, if anything you want it toed in alittle bit since your camber is so negetive. if you want your tires to last i would get a camber kit for the front and back. camber and toe is what makes your tires wear good or bad.
Old Nov 30, 2009 | 09:02 PM
Tyson's Avatar
what do you mean? camber doesnt affect how a car "pulls", unless its a huge cross camber.
Old Nov 30, 2009 | 09:03 PM
DCRB's Avatar
ugh not this again... let the camber/toe battles begin
killercrx91
Sep 23, 2008 08:16 PM
redDAinteg
Apr 29, 2008 06:30 AM
drumminforev
33
Apr 7, 2006 02:02 PM
nichols_si
10
May 6, 2004 05:58 AM
96 SOHC VTEC
Jan 5, 2003 04:34 PM
