compression numbers for my jdm h22a..is this good?
honda newbie....
the compression test was done on my jdm h22a swapepd accord. i used the autozone rental compression tester...(looks like a cheapie..)
cylinders:
1. 180 psi
2. 179 psi
3. 179 psi
4 180 psi
this within specs??
cylinders:
1. 180 psi
2. 179 psi
3. 179 psi
4 180 psi
this within specs??
btw i preformed it cause my buddy told me i would shoot BLUE plumes of smoke outta my exhaust.... i found out that oil was getting sucked in by the intake from the hose connected to the intake and valve cover
According to the HELMS, 135PSI or above is fine on an H22 what's important is that all four cylinders are less them 10% different from each other.
Drew Peacock
Aug 18, 2003 07:25 PM
