Shaved block and head.. is it safe to use high performance camshafts?
Old Nov 29, 2009 | 06:06 PM
KangBanger's Avatar
Default Shaved block and head.. is it safe to use high performance camshafts?
I have a B18C1 bored out to 81.25 with RS Machine ITR pistons. I shaved the block and the head. I had to use the adjustable cam gears to get the timing right, since the engine was shorter. i had to move about 1 to 1.5 click on the cam gears.
I was thinking about upgrading the camshafts and i was worried that the valves will hit the piston if i get performance camshafts, since now the valves are closer to pistons. Is that the case? If i were to do this, of course i will upgrade the valve springs. Is it necessary to change the valves? could i get by with out changing them?
What are the difference between stock retainer to aftermarket ones. do i have to get same brands to seat the spring to retainer correctly?
Thank you.
D16A6killer
18
Jul 24, 2010 05:24 PM
97twodoor
11
Jun 5, 2009 03:40 PM
Goldpow85
29
Mar 23, 2009 09:23 PM
tuanhoprosk8
14
Aug 22, 2005 09:22 AM
Gmedalion
Apr 15, 2002 09:04 AM
