02 Accords Coupe EX - Low gas Indicator light is not working
Old Nov 29, 2009 | 04:13 PM
moddhu's Avatar
Default 02 Accords Coupe EX - Low gas Indicator light is not working
I have a 02 Accord EX coupe. recently i ran out of gas and my car was stuck on road, i called up road side assitance guy and he filled 2 gallons of gas. Since the the indicator never showed up though it the car is completely running out of gas!
I tried checking the indicator before starting the engine.. it is ont comng up where all the other indicators seem to be working fine
Any ideas, what could have gone wrong? If i need to fix it, how much it may cost, any ideas?
Thanks a lot in advace... this forum is really helpful!
Old Nov 29, 2009 | 04:35 PM
redbull-1's Avatar
Default Re: 02 Accords Coupe EX - Low gas Indicator light is not working
If the fuel gauge works and the light doesn't work, I would suspect a burnt out bulb or wiring.
If the fuel gauge didn't work, then it could be a bad sending unit; however, that doesn't seem to be what you stated.
Here is a link regarding removing the cluster:
http://www.ledautomotive.com/guide.php?id_cms=22
Old Nov 30, 2009 | 09:27 AM
moddhu's Avatar
Thanks. i will check it out.
WKD DRGN
Mar 28, 2014 09:47 PM
Ur 2 Slow 4 J
Mar 28, 2007 12:52 PM
noob with an RS
Mar 16, 2007 01:30 PM
mrudo
Jun 15, 2004 12:08 PM
DaBuccaneer Fan
11
Nov 6, 2002 11:37 AM
