help!! car not starting
Old Nov 29, 2009 | 04:00 PM
vtec_fed's Avatar
Default help!! car not starting
I have a 1999 honda prelude with a jdm h22a and a jacksonracing supercharger. One day all of a sudden it stopped starting. It turns over the fuel rails full of fuel, the fuel pump primes, theres spark. No engine codes. Every now and then it will burp like its going to fire up but doesn't. Any one have any ideas???
Old Nov 29, 2009 | 05:10 PM
Enzo15's Avatar
Default Re: help!! car not starting
Timing could be off. Make sure everything is at TDC
Old Dec 1, 2009 | 06:25 AM
vtec_fed's Avatar
timings good, im thinking coolant temp sensor or t stat??
Old Dec 1, 2009 | 06:35 AM
jordan_rael_420's Avatar
check the compression of each cylinders,
Old Dec 1, 2009 | 09:25 AM
Enzo15's Avatar
Your sure that the injectors are actually firing? And your sure that you havent flooded the motor right? Maybe try starting it with your foot on the gas pedal to let some more air in, because if the injectors are firing you might have flooded the motor by trying to keep starting it. Happened on my buddies 240sx.
Old Dec 1, 2009 | 12:39 PM
viper-blue's Avatar
I second Enzo15 on this one. I've had the same problem and the injectors weren't firing. You've got all the basics: spark, fuel, and air.
Get a friend and pull the fuel rail with the injectors attached, then turn it over and see if they are working.
Old Dec 1, 2009 | 02:47 PM
Enzo15's Avatar
Lol put the injectors in something to catch the fuel when you do this.. Otherwise it might be a big fire hazard lol
Old Dec 2, 2009 | 12:22 PM
vtec_fed's Avatar
definetly fuel becasue the engine will flood. Pull the plugs let it dry somewhat over night try again the next day and it burps like its going to start and jsut dies out, as if theres a security system preventing it from starting. And no there is no security system it was taken out with the swap. Was running perfectly fine until one day it just stopped.
Anything relevant to the coolant issue? Forgot to mention it lost awhole lot of coolant as well.
Old Dec 2, 2009 | 01:07 PM
Acidcrakker's Avatar
Cooling with not affect the car from cranking.
If you have spark and you have fuel, and it is cranking, and it is not turning on, you are missing compression. Those are the only factors that work.
hks_Racing
22
Apr 11, 2024 02:55 PM
Unidentified
Jul 24, 2007 02:13 PM
90civSi
Jun 22, 2006 12:23 PM
jthm
Jul 9, 2004 06:13 AM
Sinner
Jun 8, 2003 03:03 PM
