Speedometer problems
Old Nov 29, 2009 | 01:47 PM
puSSy's Avatar
Default Speedometer problems
So my speedo has not been working since I've owned my car (only like 2 months). I replaced my speed sensor and it still didn't do any thing. My odometer doesn't work either and the speedometer is stuck at 20 and sometimes moves a little. Also every once in a while it works. My other gauges work pretty good except every once in a while my tach dies, but its only for a second. Is their anything else I should check? How would you go about replacing the cluster its self?
puSSy's Avatar
Default Re: Speedometer problems
Also my cruise control still doesn't work. I bought the speed sensor new off of ebay.
Old Nov 29, 2009 | 01:59 PM
tamadrummer1120's Avatar
well it would be good to know the year and trim of the car. assuming its an accord
Old Nov 29, 2009 | 02:33 PM
puSSy's Avatar
yeah its a 1995 honda accord ex v6 auto
Old Nov 29, 2009 | 04:35 PM
i know that 5th gen clusters do have problems with the circuit boards in the back, mainly the speedo/odometer. I would say have your whole dash assembly taken apart down to the cluster, and go to a junikyard and ask them if you can swap it and make sure it works real quick or whatever, and then pay them, i did that for mine.
Old Nov 29, 2009 | 05:53 PM
craiger28's Avatar
Going through the same problem with my 96 EX 4 cylinder Vtec motor. First thing to do is check the wiring going under the intake and going to your VSS. You could have a bare wire rubbing against something and grounding it out. You could have a ECU/TCU issue that is making your speedo/odometer not work. I am still working through my issue.
Old Nov 29, 2009 | 08:12 PM
puSSy's Avatar
if i put a test light on it would that let me know if its working?
Old Nov 29, 2009 | 09:31 PM
nus_dogg's Avatar
Yeah, check if there's power going through and what not with a test light or volt meter.
Drola
Sep 14, 2011 07:26 AM
mothornton
Jun 30, 2011 11:10 AM
pepsi25
Jun 19, 2008 04:00 PM
watacanga
Nov 29, 2007 08:47 AM
CarreraGT2E
Apr 7, 2003 10:24 PM
