Still have problems with '97 2.2 LX...
Old Nov 29, 2009 | 12:32 PM
alonkut's Avatar
New User
Default Still have problems with '97 2.2 LX...
So, I got codes for EGR and #2 misfire...
I cleaned out EGR and also found that plug 2 and 3 was flooded
with oil...so I replaced upper and lower spark tube seals and the
valve gasket too.
But it is STILL jerky - fine when idling, but jerky when I
accelerate.
Any suggestions on what to try now?
Thanks in advance!
Old Nov 29, 2009 | 06:31 PM
craiger28's Avatar
Default Re: Still have problems with '97 2.2 LX...
#2 plug, #2 spark plug wire, Cap, rotor, dizzy. If you cleaned out your egr valve with a chemical you may have a bunch of carbon junk build up on your #2 valves making it run like crap. Take the plug out and fuel injector out of #2 cylinder and spray carb cleaner/FI cleaner in it when the vale is open on #2. This will help clean the valves. Also run seafoam in the tank and drive it.
dynamitezz
Oct 15, 2006 10:19 PM
lethalgsr32
Dec 31, 2005 03:50 PM
ltho1998
Sep 27, 2003 05:52 AM
sivicman
Mar 15, 2002 03:58 AM
