car wont warm up all the way!!!
Old Nov 29, 2009 | 07:39 AM
hon-daddy's Avatar
Default car wont warm up all the way!!!
first of all i did search for this problem but it was always other peoples themostat.
i replaced the thermo with a a brand new oem one from the dealership and i flushed out all the coolant and added new coolant.
i replaced the gauge cluster with a brand new spoon gauge cluster both gauge clusters read the same.
i got a 01 integra type r, when i start the car in the moring its cold as normal but as im driving to work it only warms up to 1/4 on the gauge, even if i drive a long distance it reads 1\4, please help
Old Nov 29, 2009 | 08:47 AM
angel_i's Avatar
Default Re: car wont warm up all the way!!!
Faulty coolant temperature sensor? Bad radiator temp sensor?
Old Nov 29, 2009 | 08:49 AM
get RIGHT's Avatar
Sounds like there might be air bubbles trapped in the system or you have a leak somewhere letting air into it.
Old Nov 29, 2009 | 09:17 AM
hon-daddy's Avatar
thats all i can think of also it being a sensor and if air was in it wouldnt it over heat?
Old Nov 29, 2009 | 09:39 AM
hon-daddy's Avatar
radiator is oem, but not sure about the temperature sensor. ill change it out with an oem one and see if that works.
Old Nov 29, 2009 | 07:30 PM
3s1k's Avatar
Wouldn't air bubbles in the cooling system cause the cars idle to fluctuate?
Old Nov 29, 2009 | 08:03 PM
Montivious's Avatar
How cold is it outside when your driving? When I am in freezing temps my coolant gauge acts just like yours, when I am in temps above 40 degrees Fahrenheit everything acts as it should.
Old Nov 29, 2009 | 08:20 PM
JdMhEaD's Avatar
Yea, below 40 degrees, i used to have to put a piece of cardboard in front of one half of my radiator to let it warm up.
Old Nov 29, 2009 | 10:24 PM
PaulMc's Avatar
Painfully Stupid
My same car does that sometimes to, and sometimes it reads normal right before the half line. Haven't cared enough yet to look into it.
Keep us updated on what you do to fix it, hopfully saving me some time.
Old Nov 29, 2009 | 11:45 PM
MiraiZ's Avatar
Its probably your spoon gauge, I have one and the h2o temperature gauge isn't accurate (neither is the OEM one)....get a proper h2o gauge.
Old Nov 30, 2009 | 06:06 AM
hon-daddy's Avatar
I live in Texas, it's hot as hell over here.
Old Nov 30, 2009 | 06:10 AM
hon-daddy's Avatar
Both my old and new gauge clusters read the same.
Old Nov 30, 2009 | 06:40 AM
hon-daddy's Avatar
i also found this.
http://www.team-integra.net/forum/di...8&ThreadPage=1
Old Dec 3, 2009 | 08:53 PM
hon-daddy's Avatar
changed out the ect sensor and it still reads the same!!
Old Dec 5, 2009 | 03:42 AM
touge's Avatar
My 98 UK ITR does the same thing, the temp gauge only goes up about 1/4 the way but the car runs perfect and is actually getting up to temp fine so it never bothered me.
Old Dec 5, 2009 | 05:01 AM
ninor's Avatar
Thermostat stuck open?
Old Dec 5, 2009 | 01:06 PM
hon-daddy's Avatar
i tested it and its brand new.
Old Dec 10, 2009 | 06:07 PM
DX Hybridizer's Avatar
I feel your pain. I'm having the same issue right now on a 00 Civic SI. I just changed out the thermo and coolant. The last set of coolant was blue so maybe a water wetter was in mine.
The tube from the termo down to the rad isn't getting warm either. Even after the engine sits at idle at gets up to the fan switch temp. But when driving it just drops. Confirmed no air in my system either.
Let me know as you press on, I'll share any changes I find. Today was a high of 26F here. Worse case I might try the cardboard trick. I had to do that on a previous b16 I owned. This is the first winter with this car for me.
Old Dec 10, 2009 | 08:22 PM
hon-daddy's Avatar
wasnt the mother fuc%^%$ing sending unit either!!! i changed out the thermo, ect sensor, sending unit, gauge cluster and coolant.. what the hell? still reads 1/4. ima try the cardboard thing when i get a chance. what else could it be? i changed everything out lol
Old Dec 11, 2009 | 01:08 PM
Jackson's Avatar
Have you let the car idle long enough to warm up? The fan should kick on once the car is up to operating temps. Does it still come on?
Old Dec 14, 2009 | 05:03 PM
hon-daddy's Avatar
i changed out the sending unit and nothing. still reads the same, starting to get pissed lol please help.. i changed out everything that could posibly b the problem i think... i changed out the gauge cluster, coolant, thermo, ect sensor, sending unit. all i want for Christmas is my car to run warm
Old Dec 14, 2009 | 10:00 PM
PaulMc's Avatar
Painfully Stupid
I recently hit an animal in the road and replaced my stock oem radiator with an aftermarket one, since then, the car will warm up to normal at idle, but after driving, the needle reads as if the car is cooling down, sometimes the needle is at the C, sometimes vtec will cross over hard, sometimes not at all, same with the heat, any suggestions, tips, advice?
Old Dec 16, 2009 | 04:54 AM
hon-daddy's Avatar
bump.
Old Dec 16, 2009 | 08:54 AM
b18c5 power's Avatar
On my itr 1/4 of the gauge is perfect running temp, ( or two space from cold or two space back from middle)???
Old Dec 16, 2009 | 11:16 AM
hon-daddy's Avatar
ive never heard of 1/4th on the gauge being perfect temp. this is my second 01 itr and the first one i had read 1/2, so does every other itr i see.
