MSD Injectors
anybody know any specs on these? I have the opportunity to purchase 395cc injectors they are high impedance. What injector clips do they use. The part number is MSD 2068. Lmk what you think or any past experiences.
It's a 12 ohm injector. You can use the OEM honda injector clips if you cut out the tab on the inside of the injector connector.
I used the same model 2068's for over 4 years. Easy to dial in the idle and the curve is linear enough that it doesn't have any weird spots that require a lot of compensation.
what are the pro's and cons to having the rochester type injector? I tried searching but got no definitive answers. What type of injector does rc use? thanks allot.
Are there any pro's and cons to using this injector over say an RC? i've used Rc in the past. Never really noticed much beside being able to tune my car without upping my fuel pressure. Will there be any hiccups or downfalls? with using a delphi/rochester style injector?
Keith Pierson's bitch
Oct 16, 2005 09:26 AM
