Calling ALL BC5 Cammed Motors
Old Nov 28, 2009 | 11:01 PM
EG-B20vtec's Avatar
Default Calling ALL BC5 Cammed Motors
I have searched and searched and searched!
These have to be the worst selling cams of all time!
Is it seriously that BIG of a cam that no one will use it?
I have this cam sitting here ready to go and can't find doo-doo for comparison!
If you have had them please post a brief summary of your setup and any comments or dynos.
I have only seen a very few number of people actually running them...come on!
WTF!?!
If nothing else this can be an informative thread for anyone considering them.
Old Nov 29, 2009 | 06:47 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Calling ALL BC5 Cammed Motors
search under users 92TypeR and Teamdiesel.
Old Nov 29, 2009 | 07:11 AM
Teamdiesel's Avatar
I use them and I am on my way to the dyno now. Will post results as soon as I get back .
Old Nov 29, 2009 | 08:15 AM
92TypeR's Avatar
FSAE
They are good cams, but Pro3's are better, more power everywhere, with the same peak RPM HP. I was running BC5's for a few months after my friend took them out of his 86x89 14:1 motor. He was making ~270ish before selling the motor.
Here is the graph of BC5's vs Pro3's on my motor.
Old Nov 30, 2009 | 08:07 AM
EG-B20vtec's Avatar
I know there are more of you BC5 jerks out there c'mon!
Thanks to all who have teken the time to comment!
More Please!
Old Nov 30, 2009 | 11:52 AM
Teamdiesel's Avatar
I must say that I am very dissappointed with the results from the BC5 cams. I think there is an issue with my map as I have tried three different cams on this setup and all of them share a large dip in the 4800-5500 range. I made a best of 248/167 with my old skunk2 tuner3 cams but the dyno operator deleted it so I overlayed a base run with my tuner3's over the Bc5 cams. My best run with the Bc5's was 239/159.
run 36 S2S3
run 53 BC5
Old Dec 1, 2009 | 06:18 AM
Killer4Sho's Avatar
I find it rather strange that a bigger cam would make less power in a high compression/displacement motor.. the car probably needs a fine tune as well with those primaries being bigger than a tuner series cam. Did you get to do any cam gear adjustments with these on the dyno or were they left at 0,0?
Old Dec 1, 2009 | 11:56 AM
Rollo Lawson's Avatar
run 36 S2S3
run 53 BC5
Deez, u've cant expect the motor to produce good power running the same map with ANY of the cams u've installed. if anything, its very vivid indication that ur current generic map its not working seeing that u made the most power with the cams that have the smallest lobes. is tuning still an issue down there?
Old Dec 1, 2009 | 12:51 PM
92TypeR's Avatar
FSAE
I looked over his Hondata maps last night. Timing remained unchanged between both camshafts. Simply from the change in cranking pressure he described to me, there should be more ignition timing on both the low and high cam. I think he said we was going to re-dyno this afternoon with some timing changes I suggested.
Unfortunately, it sounds like the availability of consistent pump gas is an issue on his island. His static CR is ~13.4:1, and he is running some blend of 89-91 octane. It would require some large margin of error in the ignition.
My two cents.
Old Dec 1, 2009 | 06:49 PM
Teamdiesel's Avatar
We basically have no real tuners on the island as far as I know. There are a few guys who try a thing or two like myself, but no certified tuners. I always start with the original map when using a different cam, and do changes on the dyno. I actually dyno on a mix of C14 and pump gas and daily drive on 89-91 octane.
Old Dec 2, 2009 | 01:42 PM
93-lsvtec-eh2's Avatar
just as 92typer said. i used them in my build also but after we tested them we tested the pro 3's and they made more power everywhere. pro3's were the obvious choice
Old Dec 2, 2009 | 01:56 PM
Teamdiesel's Avatar
what were you dyno numbers with the BC5's vs Pro3's? Any track times on your setup?
Old Dec 4, 2009 | 07:43 AM
i would have to do some digging the runs were made on a engine dyno
as far as track times it ran a 12.36 at 113 and the car was having major ignition problems with aem ems at the time and only had about 25degrees of total timing
AllMotorKiDD
10
Dec 2, 2011 09:27 AM
SpoonSleeper
Dec 16, 2009 06:13 AM
athoughts
Jan 21, 2005 02:32 PM
TwistedHatch
18
Sep 8, 2004 01:56 PM
