WA 1991 Mazda Miata w/ extras - $4500
Old Nov 28, 2009 | 07:29 PM
JayK's Avatar
Default 1991 Mazda Miata w/ extras - $4000 *PRICE REDUCED*
Selling a 1991 Mazda Miata. 1.6L engine with 150K miles. Clean title. 5 speed manual. Runs strong. Compression recently checked; 185psi across all cylinders (190psi is factory spec). Gets 26-30mpg. More on the highway. Has AC and power steering. Comes with many extras.
Engine and Drivetrain
Non-modified engine
New automatic transmission radiator (greater capacity)
Timing belt/water pump/drive belts replaced
New coolant temp. sensor and new coolant thermosensor
New fuel filter
New Bosch O2 sensor
Factory NGK spark plugs and wires
Mazdaspeed Engine Oil Cap
Racing Beat Intake
Roadstersport Race Exhaust
Mazdaspeed Motor Mounts
Clutch/pressure plate replaced - flywheel resurfaced/lightened
New clutch slave cylinder
New Rear cam seals
New Shifter bushings
Suspension/Chassis/Brakes/Wheels/Tires
Rota Slipstream 15x7 wheels +25 offset
Dunlop Direzza Z1 Star Spec tires 195/55/15
QA1 springs (400lbs front, 300lbs rear)
Koni Yellow shocks
Koni coilover sleeves
Energy Suspension spring isolators
Mazda Miata 1993 LE outer tie rod ends
Fat Cat Motorsports front upper shock mounts
Flyin' Miata rear upper shock mounts
Fat Cat Motorsports bumpstops
Jackson Racing front and rear sway bar
New Axxis Ultimate front brake pads
New front rotors
Front wheel bearings replaced ~20K miles ago
Rear wheel bearings replaced ~4K miles ago
New and updated alignment eccentric bolts and cams
Exterior
OEM R-package front lip
OEM Hardtop painted black w/ factory latches
APR Carbon Fiber Door mirrors
3rd Brake light blinker module
Hella H4 headlight conversion E-codes w/ Sylvania Silverstar bulbs
Mesh grill
Interior
OEM cupholder
Auger Resources shifter and e-brake boots (suede black w/ red stitching) - no longer produced
Boss Frog Clearview Roll Bar (SCCA approved)
Headrest speakers
1997 Miata sun visors (single piece) - pass. side has vanity mirror
Comes with many extra parts as well (spare tire, stock steering wheel, spare valve covers... etc). I will admit, the car is not perfect. The paint, although still shiny has some dings and chips. The right rear quarter panel has a dent which has been masked by a spiffy looking band-aid decal. Car needs to go to support my new hobby. Email or PM me for more info.
Old Nov 29, 2009 | 06:29 AM
DougiePants's Avatar
Default Re: 1991 Mazda Miata w/ extras - $4500
bump for viewing
Old Nov 30, 2009 | 11:47 PM
JayK's Avatar
bump
Old Dec 2, 2009 | 09:50 PM
JayK's Avatar
ttt
Old Dec 8, 2009 | 03:08 AM
JayK's Avatar
bump - price reduced to $4000
Old Dec 8, 2009 | 09:36 AM
JayK's Avatar
ttt
Old Dec 10, 2009 | 08:34 PM
JayK's Avatar
bumpity
Old Dec 11, 2009 | 07:47 PM
JayK's Avatar
boop
Old Dec 15, 2009 | 03:42 PM
JayK's Avatar
bumps
Old Mar 4, 2010 | 04:20 PM
Sixty_Four's Avatar
still available?
price now?
Old Mar 4, 2010 | 04:41 PM
srt4mike's Avatar
Nice lookin' bay
EJ8_Man
Northern California (Sales)
Jan 5, 2015 06:07 PM
speedstar-racing
Aug 29, 2014 05:04 PM
SideFX
Dec 15, 2010 02:02 PM
eg ferio
Feb 7, 2007 03:03 PM
zo7vette
May 19, 2006 03:32 PM
