gas tank problems?
Old Nov 28, 2009 | 10:18 AM
Ferio4ya's Avatar
Default gas tank problems?
i'm driving down the road, car begins to die (drops rpms), everything is working properly, and it has down this 3 or 4 times, and i noticed it does this when i'm about 1/4 tank of gas. it acts like there isn't any, i push the clutch and down shift, drops rpm's still, i went from 45mph down to 15mph then boom, it picks up no problem and drives normally, i head to the gas station fill up and it stops doing that. but, 1/4 tank and again it suddenly does it randomly, so i hit up the gas station again and it runs fine. my only CEL code is 41 (primary 02 sensor) which is not plugged at the moment because the harness of the o2 sensor got snipped, but i'm not sure if this is the problem, i think its something going on in the fuel tank. the fuel pump btw is brand new only about 2000 miles on it cause i replaced it when it first did this ****. but it still continues. i checked fuel lines and they are fine, no leaks. the fuel filter is brand new after my swap which was about 4000 miles ago. should i drain the fuel tank and take a look?? any suggestions to anything thanks!
Old Nov 28, 2009 | 10:49 AM
Ferio4ya's Avatar
Default Re: gas tank problems?
oh i forgot to mention, i did research this topic and it was never actually concluded. you can research it yourself and let me know if something i did is missing. thanks!
Old Nov 28, 2009 | 01:06 PM
x32laro's Avatar
bump for answer
Old Nov 29, 2009 | 03:47 PM
Ferio4ya's Avatar
thx ttt
Old Nov 29, 2009 | 04:27 PM
Dkober101's Avatar
bad fuel pump or dirty fuel filter would have been my guess.
bump and good luck OP
Edit: When you were at a "1/4" how much gas were you able to put back into the tank (should be around 8-9 gallons) ? Maybe your gauge is going bad, or the float in the tank is getting hung up causing you to actually run out of gas but you needle is still telling you that you have a "1/4" tank left.
Old Nov 30, 2009 | 11:21 AM
Ferio4ya's Avatar
that was my guess as well, so i replaced both already but still the same problem. i think you may be right though, 1/4 tank is how many gallons?? i was able to put back in approximately six gallons back in to be completely full. so i'm thinking 1/4 is like 2 or 3 gallons?? that could be the issue, i'll research how to take a look at this issue and is replacing gauge hard? again, thx
Old Nov 30, 2009 | 11:31 AM
Former User's Avatar
This thread may interest you.
Old Nov 30, 2009 | 01:17 PM
Ferio4ya's Avatar
RonJ@HT, always a good man. thanks so much for the help. You always have to best advice IMO. Thanks!
VTECwalka
Jan 21, 2013 02:19 PM
theEFkid
Mar 20, 2012 11:52 AM
spookum
Jan 31, 2011 04:32 PM
rasinhell
10
May 15, 2005 07:15 PM
hYpE-R-29
Nov 1, 2003 07:27 AM
