HYBRID89's Garage CLEARANCE - EF/EG/DC - B & D Series - Lotz of PARTS!!!
Old Nov 28, 2009 | 09:06 AM
hybrid89's Avatar
Default UPDATED! 4/21/13 - HYBRID89's Garage CLEARANCE - EF/EG/DC - B & D Series - FS/FT
UPDATED! UPDATED! UPDATED! --- 4/21/2013 NEW PARTS ADDED / PRICES Dropped AGAIN--- UPDATED! UPDATED! UPDATED!
I have a ton of parts as some of you who have bought off me in the past can vouch for. Most is for EF/EG/DC Chassis and either D or B series engines. I will try my best to be as accurate about each item and I have never been here to rip anyone off. If you buy a part and it doesn't work out, get it back to me (at your expense and time) and we will work out a solution. All parts are sold AS-IS. I am willing to ship anywhere in the continental US at buyers expense. Parts can also be arranged for pick up locally (91387). Parts are priced for local pickup. Hit me up for a quote for shipping. Will also give a discount for multiple items per shipment. I ACCEPT PAYPAL AND CASH ONLY FOR PAYMENT!
DISCLAIMER - I will do my best to get items shipped out ASAP after payment/ meet up to exchange money for parts, but I must warn you. I work a lot of hours during the week for my company. I own a company and have business to deal with. Cars come second to my family and job. So, without to much more...on to the parts!
WILLING TO TRADE PARTS (+/- CASH ON EITHER END) FOR THESE ITEMS ONLY!:
ACT 12lb flywheel and/or ACT HD pressure plate for B series
81-84mm forged pistons (8.5-10:1 comp range) w/ rings and wrist pins - let me know what you got!
OEM B series Axles (non SRS / NO ripped boots)
HASport B series/EG mounts
OEM ITR head internals (Valve springs/retainers/cams)
FOR SALE --- FOR SALE --- FOR SALE --- FOR SALE --- FOR SALE --- FOR SALE --- FOR SALE
************************************B Series Parts*********************************
B16a1 metal vacuum hose (on top of head) passage way - make offer
B16a1 Fast Idle Valve (below throttle body) works great! - $30 obo
(2)B16a1 Dash Pots (on top of throttle body) works great! - $20 each obo
94-01 Integra AUTO transmission front mount. No tears/rips - $20 obo
B16a1 OEM cams (70k) --- $30 pair
B series exhaust manifold support bracket - $8
B series Rear Main Seal Plate - $10 each
B series (PR3) VTEC Lower Timing Belt Covers - $15 each for lower . Others sold!
B series (PR4) Inner middle Timing Belt Covers - $10 each
Have 2 sets of each....Only work on LS and B20 heads - NON Vtec
B series LOWER Power Steering Brackets - $10 each
Top to Bottom = P73 (ITR) - SOLD, P54 (Del Sol Vtec), PR4(LS Non vtec) x1 (1 SOLD / 1 available)
Ugly B series oil pan (non GSR) no leaks/ just slightly dented and missing paint - $20 OBO
************************************D Series Parts*********************************
D series (88-95) Left/drivers side Motor Mount Support Brackets (3 of them) $8 each
BNIB Honda OEM D series 92-95 Intake manifold gasket --- $12
(4) OEM used D series starters - all work just fine --- $20 OBO each
*************************************EG/DC Parts**********************************
OEM EG front Tow Hooks - $15
EG Dash switches - Moon Roof / Light Dimmer / Cruise - $10 per switch/ $25 for set of 3 switches / block off plates - $3 each -let me know which ones you want, I will mix and match (they all work)
Block Off Plates
Black Blox Rear LCA's - 3k miles on them, strut bushings have a little wear from my bad RTA bushings, but still work great and are cheap/easy to replace if needed from Blox. These will fit any 92-00 civic / 94-01 integra (non ITR)
I went to a spherical setup since replacing all my rear bushings - $75
94-01 JDM ITR Rear LCA (right side) bushings are good/has a little surface rust from overseas - $$$ make offer
EG OEM Main Relay - No cracks / Works perfect. Bought a new one when I thought it was the culprit for a non start issue.
100% working - $35
EG E-brake console BLACK (bare) - $15
EG Inner door handle garnish/covers BLUE - $15 pair
EG hatchback Seatbelts BLUE - COMPLETE SET - $45 all / willing to seperate
MISC EG interior parts ALL BLUE - $make offer on ANYTHING or EVERYTHING
Complete 92 CX Civic hatchback wiring harness (minus main cabin harness (ECU thru firewall and engine harness) willing to sell any and all portions left portions- $40 for rest of available harness
EG OEM Radiator Fan (used and has 1 lower broken tab) - still works great --- $20
96-01 DC2 ABS Sensor w/ pigtails - $30 set of 4 (will sell single for $10 each)
EG/DC front suspension forks - pair $20
RED EG Door handles (left and right) - $20 pair
WHITE EG Door handles (left and right) - $20 pair
EG manual window regulator. DRIVER SIDE SOLD / Passenger Available - $25
EG Under Steering Column metal brace --- $ MAKE OFFER
EG Under Glove Box metal cross brace --- $ MAKE OFFER
EG CX OEM Intake Arm --- $ MAKE OFFER
EG OEM Shift boot (black) clean/ no tears/no holes - $10
****************************************EF Parts***********************************
88-91 EF Manual Transmission Rear Mount Brackets (2 of them) cable trans ONLY! - $15 each
88-91 EF AUTO Transmission Rear Mount Bracket - cable trans ONLY! - $10
EF Horn - works fine! - $12
EF AC Bracket w/ hardware - $20
EF (CABLE) Si Empty Transmission Case - inner and outer halves. This was a 100% working trans when I tore it apart to learn the aspect of Honda transmissions back in the day. I sold all the guts to a SCCA guy and have this left over. completely bare halves, ready to clean and assemble. - $40 OBO
EF OEM Radiator fan (used but works great) --- $25
(2) 89 CRX Window Washed Fluid reservoirs (both used with lines) --- $10 each
EF Main Power Distribution Box (with all fuses / used) - $15
88*91 Ef OEM Exhaust Manifold Complete with single wire O2 sensor/donut gasket - $40
****************************************Universal Parts***********************************
BNIB SPC Camber Ball Joints (part # 67320) for:
TSX 2004-up, CL 2.2L 1996-97, CL 2.3L 1998-99, TL 2.5L 1996-98, CL 3.0L 1996-99, CL 3.2L 2001-04, TL 3.2L 1999-04, Accord 1998-04, Civic/CRX 1989-91, Odyssey 1995-98 - +1.5 - +3.0 degrees adjustment. In my opinion its either this or a full control arm. I hate cheap camber kits for safety. This is the real deal! --- $125 pair
EF/EG/DC Charcoal Canister w/ drain tube - $20
BRAND NEW "Real Deal" Brembo cross drilled REAR ROTORS 4 x100 - $75 pair
Used Intake Filters( all low milage, but need cleaning) - Misc Brands/ ALL 3" inlet size - $10 each
2 on left standard K&N style, 1 one right is metal screen style - MIDDLE FILTER SOLD - LEFT AND RIGHT STILL AVAILABLE!
Moroso Anti Roll/ Line Lock kit BRAND NEW - $80
BNIB Generic Ball Bearing Short Shifter. Fits any 88-00 civic/90-2001 Integra - $20
Pics to come:
(4) D series Oil Pickups --- $ 10 each
SOLD SOLD SOLD! --- Thanks to everyone below for purchasing these parts off me!
SOHC STR ALUMINUM CAM SEAL (RED) USED - SOLD to d1692hatch
EF (maybe more) SRR aftermarket Tie Rod ends - SOLD to bobalee
Benen front lower brace - SOLD to s14-13b
after market power door lock solenoids - SOLD to SolChild93
PLACE RACING B SERIES INTO EF SHIFT LINKAGE - SOLD to dumaU
**NEW** HAYAME B SERIES FUEL RAIL (RED) - SOLD to Shane_00Integra
B Series into EF Chassis Rear Transmission Bracket (Cable Trans ONLY!) - SOLD to midge_ef
p05 ECU ( virgin) - SOLD to ej8
96 B20B rods and pistons - SOLD to .wtf
97 civic DX Wheel Covers / Hub Caps - SOLD to atesicks
89 CRX center Tail Light w/ clean decal - SOLD to FOMULA91
USDM Integra Type R DB8 rear seat (Top ONLY) - faded - SOLD to madcrossover
USDM Integra Type R DC2 Rear Seat (BOTTOM ONLY) - SUPER CLEAN! - SOLD to madcrossover
EG srs computer and wiring harness (no cable real) - SOLD to themobiledc
Z10 B series lower block girdle and EG Momo hub - SOLD to 91_rex_ls-vtec
Type R and LS Power Steering brackets - SOLD to DO_ITR_YoungD_19
PLACE RACING B INTO EF AXLES, EF Civic 4dr rear door handles,3" Intake Filter - SOLD to joshd_bh
92 CX Main cabin harness - SOLD to ShyroJupiter
EG complete dash harness (UNCUT except STEREO plugs) - SOLD to 9honda5civic
BNIB OEM LS headgasket, BNIB OEM B16 Timing belt, B20 Oil Pan - SOLD to da9blk1
DC2 rear lower control arms (fits EG) - SOLD to 0-man
14" x 5" (32 offset) 4x100 Honda "steelies" pulled from a 97 civic DX - SOLD to LwdJdmR
Used (8k) D series CABLE OEM clutch disk - SOLD to Fittest224
B16A1 BARE BLOCK - Includes main caps - TRADED to civic00sir.
12.9" Wilwood Dynalite BBK - Traded to pilotOnDubs
oil squirters and GSR valves - SOLD to vtechjunkie
USED OEM EG gas tank level sensor/float - SOLD to o-man
BRAND NEW CAMP1320 C Pillar Bar BLACK CHROME - Sold to john159753
95 GSR Dual Bend Shifter - SOLD to Hybrid96EK
95 GSR Alternator Brackets ( Top and Bottom) + hardware - SOLD to Marvlus_
Eg manual window regulator, handle /clip - SOLD to Jdmefsir12
EG OEM camber arms - SOLD to accord91guy
B16A1 IACV - SOLD to usdmEHboy
95 JDM GSR ECU - SOLD to ej0513
17 tooth x 24MM ZC timing gear - SOLD to Jarrat
4 GSR Oil Squirters - SOLD to deckster333
OEM DC Front Motor Mount & OEM EG/DC Torque Mounts - SOLD to fonkernuckle
P72 upper power steering bracket - SOLD to nvrl8
B series (PR3) VTEC Lower and B series OEM catch can - SOLD to crxin
OEM USDM Eg hatch/coupe corner lights - SOLD to jawsiiv
96 GSR OEM knock sensor - SOLD to swiftEJ_95
eg dimmer switch/cruise control switches - SOLD to xivsavagevix
Old Nov 28, 2009 | 09:53 AM
hybrid89's Avatar
Default Re: HYBRID89's Garage CLEARANCE - EF/EG/DC - B & D Series - Lotz of PARTS!!!
TTT - now that I got my image hosting to work...lol
Old Nov 28, 2009 | 12:07 PM
hybrid89's Avatar
ttt
Old Nov 28, 2009 | 12:43 PM
hybrid89's Avatar
MORE ADDED
Old Nov 28, 2009 | 02:23 PM
hybrid89's Avatar
all prices obo...i have so many things to go through..this is just a taste...
Old Nov 28, 2009 | 04:24 PM
hybrid89's Avatar
up up and away
Old Nov 29, 2009 | 08:33 AM
hybrid89's Avatar
ttt
Old Nov 29, 2009 | 11:18 AM
hybrid89's Avatar
ttt
Old Nov 29, 2009 | 11:26 AM
FRESHTEG's Avatar
bump
Old Nov 29, 2009 | 11:33 AM
Black-Ty [EG6]'s Avatar
bump
Old Nov 29, 2009 | 05:52 PM
hybrid89's Avatar
thanks for the bumps!
Old Nov 29, 2009 | 07:04 PM
rhdej6's Avatar
edfc ftw
Old Nov 29, 2009 | 07:06 PM
Too_slow_eg's Avatar
bump
Old Nov 30, 2009 | 05:56 AM
hybrid89's Avatar
ttt
Old Nov 30, 2009 | 11:57 AM
hybrid89's Avatar
ttt
Old Nov 30, 2009 | 12:20 PM
JDMInteg96's Avatar
ttt
Old Nov 30, 2009 | 07:03 PM
hybrid89's Avatar
ttt
Old Dec 1, 2009 | 06:21 PM
hybrid89's Avatar
ttt
Old Dec 1, 2009 | 07:07 PM
JDMInteg96's Avatar
sell this stuff
Old Dec 2, 2009 | 10:14 AM
hybrid89's Avatar
Originally Posted by JDMInteg96
sell this stuff
Thats right..so I can buy this guys engine!...
Old Dec 3, 2009 | 09:46 AM
hybrid89's Avatar
ttt
Old Dec 4, 2009 | 07:43 PM
hybrid89's Avatar
OBO
Old Dec 5, 2009 | 03:30 PM
hybrid89's Avatar
ttt
Old Dec 8, 2009 | 12:34 PM
hybrid89's Avatar
all prices OBO..shoot me some offers want this stuff gone!
Old Dec 17, 2009 | 09:48 AM
hybrid89's Avatar
ttt
