radiator fan is not turning on
sorry about being so vague. i was watching something on tv when i typed it out the first post
its a 95 civic si w/ b16a swap. there is a plug that connects to the radiator fan that it gets its power from. i hooked the radiator side of the plug directly to the battery and the fan turns on. so, im not sure if the problem lies within that plug or a temp sensor or what?
Sorry, I do not have a wiring schematic for a 95 Civic so I am not sure if the rad fan relay supplies the rad fan with a ground or 12V+, probably 12V+.
We already know it is not a rad fan problem, so it must be either no power or no ground.
The first thing to do is test at the plug, [wire harness side] is there a ground, [or power] at one of the pins?
If there is a power or a ground at the plug then I would move on to the rad fan relay and supply whartever is needed, [12V+ or ground] to the lead that runs from the relay to the rad fan, to elliminate wiring or a connection as the problem.
If rad fan works when you do the above test the relay to make sure it works, if so, move to the "Engine Coolant Temperature Switch" it supplies the rad fan relay with a ground to energize it.
You can even start at that end, [ECTS], unplug it and supply a ground to it, [relay side of plug], if rad fan turns on, replace the ECTS. 94
gotnos2
Acura TL, RL & ZDX
May 25, 2012 11:23 AM
Dekorum
10
May 2, 2012 08:15 PM
hunter349
10
Jul 1, 2009 06:02 PM
