Bosch 900cc injectors Vs RC 550cc
Old Nov 28, 2009 | 06:44 AM
Turbogixxer's Avatar
Default Bosch 900cc injectors Vs RC 550cc
This is very interesting. The base pull was done on the SAME day. Rob_ and I swapped the injectors to FIC bosch 900cc and just tuned the fuel. I was hoping for 3-5whp, rob did not think he would gain. The RCs were cleaned 5000 miles ago. The both were tuned to the best we could (fuel wise). The engine temp was the same. The intake temp was the same. We tried to keep everything the same.
This was all on neptune and E85.
Enjoy
Old Nov 28, 2009 | 10:30 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Bosch 900cc injectors Vs RC 550cc
Thank you for posting this results. Hopefully others will take heed.
Old Nov 28, 2009 | 10:34 AM
00Red_SiR's Avatar
All Motor Mentor
That's impressive. Is it simply an enhanced spray pattern that gives them a power advantage like that?
Old Nov 28, 2009 | 11:26 AM
Yes, and the control of the injector is a lot better.
Old Nov 28, 2009 | 02:57 PM
88ED8's Avatar
Nice!!!
Old Nov 28, 2009 | 03:42 PM
92TypeR's Avatar
FSAE
Thanks for sharing!
Further gains could be seen with injector timing adjustment.
Are the Bosch 900cc the same family of injector as the ID725 and ID1000?
Old Nov 29, 2009 | 06:17 AM
Originally Posted by 92TypeR
Thanks for sharing!
Yeah, with injector phasing, we could pick up more. I wanted a test of just changing the fuel.
Yes. The Fuel injector clinic 900cc is in the same family as the ID750/1000. It is argued what one is better or "correct". Info on the FIC: http://www.fuelinjectorclinic.com/injectors/honda.html
Old Nov 29, 2009 | 06:31 AM
killerpenguin21's Avatar
so basically rc injectors arent that good?
im not sure what i should take away from this since i run smaller injectors than you tested?
Old Nov 29, 2009 | 06:35 AM
It is not that RCs are not good, they are old technology. With new injectors, you can see better driveability and most likely more power.
They make the newer bosch injectors in smaller sizes too. So you *could* gain more. He brought 900cc because he is going turbo later and has two kits of dry nitrous now.
Old Nov 29, 2009 | 06:47 AM
mar778c's Avatar
Community Builder
I've only keep up with the ID stuff based on some dyno plots, talking to some tuners, and info from there website. The FIC and ID injectors are the same item but the IDs are tested and matched via dead time, response time, etc and they give you the battery compensation and injector pulse width data, etc. The process they go thru with ID is what makes them superior if the tuner knows how to take advantage of the information.
Old Nov 29, 2009 | 07:06 AM
As what info they come with, they both come with dead times, injector flow sheets. I have ID1000s on my car. I do not know what FIC process of matching them, because they do not make it as public as ID does, so I can not answer that question. I have tuned a good amount of both ID and FIC. I have never tuned both on one car. I can email FIC on it and see what they have to say.
That was going to be my next test, but I will probably not make it public. I do not want the drama from it. That why I labeled the thread bosch 900cc, not FIC or ID.
Old Nov 29, 2009 | 08:07 AM
92TypeR's Avatar
FSAE
For us N/A guys, it seems these would be the most likely option:
http://www.fuelinjectorclinic.com/cg...ey=IS115-0525H
Old Nov 29, 2009 | 09:07 AM
mar778c's Avatar
Community Builder
Unfortunately, what you say is true and sad because the community would benefit from this info.
From what I've seen on simple rebuild all motor cars, the FIC/generic injector would probably be good enough. For turbo 450+ whp, I would use the IDs because of the matching process and plenty of examples of very high whp cars using them with great success.
Old Nov 29, 2009 | 09:17 AM
d112crzy's Avatar
Great post, sir.
Old Nov 29, 2009 | 10:00 AM
I have made very good power on FIC 900cc. I just can not comment on how they match them up, because I do not know.
I try to make my tests as fair as possible. Like you said, it is sad. If a part works and it is cheaper, then it should be used. I am not saying either one is better, because I do not know. I just see too many loaded tests from biased sources.
Old Nov 29, 2009 | 02:05 PM
Sleepy.Bear's Avatar
Would anyone happen to have a picture of the different spray patterns?
Old Nov 29, 2009 | 05:34 PM
ok i understand exactly now. good to know for my new basement project
Old Nov 29, 2009 | 05:46 PM
Furyof4's Avatar
Thank for for sharing this info.
Old Nov 29, 2009 | 07:51 PM
mikesrex's Avatar
do you have a graph of the A/F ratios for both of these pulls?
Old Nov 30, 2009 | 06:20 AM
OH_1fstgsr's Avatar
I have a similar question to this.
If the spray pattern is improved for atomization shouldn't the dyno graph show the same/similar improvement everywhere?
Or is it improved slightly and as the air velocity increases the impact is more prevalent.
Just a thought.
Old Nov 30, 2009 | 06:44 AM
92TypeR's Avatar
FSAE
I think port velocity plays a large role in this.
If you think about the power gains in terms of a % increase and not a constant, the difference will be less at lower HP levels. Add in an increasing gain as port velocity increases, and your dyno curve starts to resemble the OP's.
Simply adjusting injector timing plays a large role in power. This is a curve of one of the restricted 599cc FSAE motors I built. The six curves all have a different base injector timing. The timing values are noted in the subtitle for each run file, measured in * ATDC. Our engine dyno could only measure 7,000 RPM worth of data at 100 RPM step size, so these runs started at 7,000 RPM and ended at 14,000 RPM, but there were little to no gains below 7,000 RPM. You can see at higher RPM's, there is as much as a 10% increase in power. Think of gaining 20whp on a 200whp B-series simply by adjusting injector timing.
Old Nov 30, 2009 | 08:01 AM
d112crzy's Avatar
Does the red say 20 or 29? Hard to tell.
Old Nov 30, 2009 | 08:14 AM
92TypeR's Avatar
FSAE
DTA20M29, each subtitle is located above the color identifier. The injector timing offset is in parentheses. eg: DTA20M29 (60deg) is the run file name, the (60deg) represents 60* ATDC.
Old Nov 30, 2009 | 08:29 AM
A Blue Lude's Avatar
What is the form factor like on these injectors? Drop in replacement for something like, say, my H22?
Old Nov 30, 2009 | 08:45 AM
OH_1fstgsr's Avatar
92TypeR, You mentioned the injector timing in your work on your FSAE car, but is that what the OP did?
"The both were tuned to the best we could (fuel wise)." Does this mean duty cycles?
