puting a head on a block
Old Nov 28, 2009 | 01:52 AM
CRXREFIC's Avatar
Default puting a head on a block
ok i finally got to the point of sticking my b18b1 head on b18a1 block, now this is my first time doing anything like this and swaping it in, how can i match up the valves with the pistons? i think in other words time it correctly in order,
right now all of the valves on the head is closed
Old Nov 28, 2009 | 01:05 PM
thumper64's Avatar
Default Re: puting a head on a block
Do you have camshafts installed in the head? There should be at least a set of valves partially open...
Old Nov 28, 2009 | 10:20 PM
CRXREFIC's Avatar
yes there is a set of valves partially opened i think the 2nd cylinder one... its a complete head so yea gots the shaft
Old Nov 28, 2009 | 10:51 PM
thumper64's Avatar
ok, you said the valves were all closed, so I was just wondering. You can't set the timing without the cams installed... Anyway, there's an UP marked on the cam gears and two marks. You point the UPs up and the marks line up with the surface of the top of the head and when cylinder 1 is at TDC, you'll have it lined up right.
Old Nov 29, 2009 | 12:10 AM
CRXREFIC's Avatar
ah ok i know wat your saying, just TDC all of the cylinder to have it lined up?
is it like doing a valve adjustment? except without adjustjing the valves? just TDC them? cause i have experience with this
Old Nov 29, 2009 | 11:10 AM
CRXREFIC's Avatar
bump im still looking for an answer
Old Nov 29, 2009 | 11:19 AM
slowhatchcali's Avatar
you need to the set crank pulley at TDC(the mark separated from the three marks), then you have set the cams at TDC also, which on the gears the word "UP" should be pointing up, they have indentations at the 3 o'clock mark and at the 9 o'clock mark which will line up, and that will be timed correctly..
Old Nov 29, 2009 | 11:38 AM
TheCivicMafia's Avatar
LOL, sounds like your about to bend some valves... But anyways, rotate cam to the up arrow, put cylinder 1 on tdc ( Make sure u actually put #1 on tdc not just the first one. ) Put your head on, Timing belt etc.. Rotate engine with a ratchet 8-10 turns slowly make sure they dont hit the valves... Start it up and adjust ignition timing with dizzy
Old Nov 29, 2009 | 12:30 PM
thumper64's Avatar
You had your answer.
Old Nov 29, 2009 | 08:59 PM
CRXREFIC's Avatar
alright thanks guys , and i already know which cylinders are which and i will not attempt this alone i always have least one person with me that knows what they're doing,
and if anyone ask y i dont ask my friends, because they never have time to show it to me without actually doing it
teejdm863
Dec 28, 2015 08:31 AM
HondaKing90
19
Feb 15, 2010 04:38 PM
HondaKing90
Engine Management and Tuning
Feb 13, 2010 09:09 AM
xwhitchx
Mar 26, 2009 02:17 PM
91-lsvtecsi
Apr 29, 2006 08:31 AM
