need help with wire harness
Old Nov 27, 2009 | 08:17 PM
v1sion's Avatar
Default need help with wire harness
okay im getting a 96jdm b18c type r on my 95 ls. can i use a gsr harness? if i can which one obd2a or obd2b and what ecu?
Old Nov 28, 2009 | 07:41 AM
10sec4door's Avatar
Default Re: need help with wire harness
If im not mistaking I think the jdm motor is obd1 so you should be able to use your harness get a gsr ecu and run a wire from ecu to vtec
Old Nov 28, 2009 | 09:50 AM
USDMCIVICHATCH's Avatar
no a 96 spec jdm type r swap is 0bd2a, and why would he use a gs-r ecu............on a type r swap?
(easiest way) use a 96-99 usdm engine harness and run the 2 vtec wires from the gang plug on the passenger shock tower to the ecu and use a chipped p28 /
Old Nov 28, 2009 | 02:34 PM
10sec4door's Avatar
Ok. for some reason I thought the jdm cars are obd1. thats why I said if im not mistaking.
Old Dec 9, 2009 | 01:57 PM
v1sion's Avatar
can i use a p30 ecu and just use a jumper harness to the jdm harness to convert it obd1 to obd2.
and if works can i pass state ref like that?
Old Dec 11, 2009 | 03:04 PM
a p30 plugs right into a 95 integra 0bd1=0bd1.......jumper harness?????jdm harness?????you can't use or need either......
kozak47
Jul 19, 2009 11:15 PM
prime-R
Mar 1, 2009 12:17 PM
Kirk@SyndromeAuto
Dec 13, 2006 05:24 PM
spinney
Jul 28, 2005 12:50 PM
cmk804
May 9, 2002 03:16 PM
