distributor plug vtec/non-vtec ?
Old Nov 27, 2009 | 06:31 PM
ONE*SICK*FERIO's Avatar
Icon6 distributor plug vtec/non-vtec ?
i bought a 93' d16z6 motor swap with engine harness from the junk yard, but someone took out the distributor and the vtec solenoid completely with plugs..
the vtec solenoid has been fixed using a 2 wire plug for the vtec switch and the single wire to the solenoid...
and found the distributor plugs out of a non-vtec harness already, but cant compare because i don't have the vtec dizzy yet..
so i'd like to know if the dizzy plug for vtec is the same as non-vtec? plug and play?
EDIT: obd1 harness--92-95 civic
Old Nov 27, 2009 | 07:34 PM
CivicSpoon's Avatar
Default Re: distributor plug vtec/non-vtec ?
'92-'95 distributors have the same plugs, regardless of whether it's for a VTEC or non-VTEC engine. So you're good to go.
Old Nov 28, 2009 | 08:43 PM
i just wired up the plugs into the harness all the wires there, same color all smoth
i'll pick up the new vtec dizzy tomorrow....
thank you!
fastdohc
Aug 31, 2010 05:31 PM
lexx
Jun 22, 2008 12:22 PM
s1267712
Jan 25, 2008 01:34 PM
sohcvtec92civicdx
Jan 10, 2005 09:59 PM
DeadVet
Nov 2, 2004 06:27 PM
