What does this mean?
Old Nov 27, 2009 | 11:44 AM
perfecteverytime's Avatar
Default What does this mean?
My SRS light came on today, so I used the two-pin connector to get the trouble code. The light flashes 9 times, followed by two quick flashes.
Thank you.
Old Nov 27, 2009 | 12:00 PM
GhostAccord's Avatar
Default Re: What does this mean?
If the SRS light is flashing 9-2 it's a Faulty SRS Power Supply.
Old Nov 27, 2009 | 12:04 PM
Thanks. Anything I can do to remedy this? Where is the power supply located?
Old Nov 27, 2009 | 12:21 PM
The power supply is the battery. First thing would be to check your SRS fuses under the dash.
Old Nov 27, 2009 | 12:27 PM
I tried 3 different fuses. They were all good 10 amp fuses.
Just a little bakground on the situation...I removed an aftermarket gauge from my car today, and was messing around down by the fuse box to remove the wires from the gauge. Is there anything down there I could have 'bumped into' while doing this. I was pretty careful, so I don't know what could have happened.
Old Nov 27, 2009 | 12:31 PM
What year is your Accord?
There could be a couple things down there that you could bump/disconnect that would cause the power to be cut from the SRS unit.
Old Nov 27, 2009 | 12:36 PM
It's a 95 accord ex sedan.
Old Nov 27, 2009 | 12:53 PM
There are two SRS fuses. No.2 15A & No.3 10A. Another thing to check is the yellow 2 pin connector coming from the fuse box. Make sure you didn't disconnect it.
Old Nov 27, 2009 | 12:55 PM
Aha! I didn't realize there was another fuze. I'll check that quick.
Old Nov 27, 2009 | 12:58 PM
redbull-1's Avatar
If everything seems okay, try resetting the SRS light and see if it comes back. Here is a link:
http://www.superhonda.com/forum/f13/...s-light-59738/
Old Nov 27, 2009 | 01:05 PM
All the fuses are good. I'll try the reset.
Old Nov 27, 2009 | 01:11 PM
In my car there is a 2 pin connector that isn't connected to anything else. Is this the correct connector to use for the reset process?
Old Nov 27, 2009 | 01:23 PM
The reset worked. No more light. However, does this mean that the problem is fixed, or does this just reset the light only. In any case, the light is gone. Thanks for the quick replies everyone!
Old Nov 27, 2009 | 01:24 PM
redbull-1's Avatar
Try this link to help you located the correct MES connector.
http://www.hondapitstop.com/accord/t...1/SRS/srs.html
Note: Do not remove the SRS Main harness plug in the under-dash fuse box.
Old Nov 27, 2009 | 01:26 PM
redbull-1's Avatar
Great. It may be fixed. You had previously removed an aftermarket gauge which may have caused it.
Old Nov 27, 2009 | 01:28 PM
The reset worked. And i didn't unplug the main harness or anything. Thanks for all the links and stuff!
khronicboy420
Dec 18, 2008 08:01 AM
toriniku
Dec 28, 2005 08:47 AM
pumafeet10
Oct 23, 2005 09:29 PM
transitions
Sep 19, 2005 10:44 PM
Speed Racer GSR
Nov 17, 2002 05:19 PM
