Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Heat in Driver's Footwell
Old Nov 27, 2009 | 11:31 AM
honda.lioness's Avatar
Default Heat in Driver's Footwell
2003 Civic Coupe here. I searched and did not turn up anything. When my Civic's climate control switches are set so hot air is supposed to blow into the driver's footwell, and even with the fan on high, it seems like hardly any hot air blows down there. When I switch so the air is supposed to blow out of the upper vents, there is a fine flow of hot air. Could others with a 2001-2005 coupe comment on how their footwell air flow is with the fan on?
Old Nov 27, 2009 | 12:18 PM
theineffable's Avatar
Default Re: Heat in Driver's Footwell
i don't think mine blows a lot of air but i've never complained about it.
if flow is low, try replacing the cabin air filters
Old Nov 27, 2009 | 01:23 PM
Pothole987's Avatar
mine seems to be low if i have it on windshield/foot option compared to face vent/foot option.
that help?
Old Nov 28, 2009 | 05:45 AM
Ineffable and Pothole987, thanks for the input. I checked my cabin filters two months ago. They seemed pretty clean but I blew them out with compressed air anyway. All of the climate control settings that involve the footwell do not show any difference; practically no flow, even with the fan on high. I will try to do more testing in the coming days. Thank you again.
Old Nov 30, 2009 | 10:53 AM
bomerman19's Avatar
it's the way the venting setup is you will get almost no airflow on your feet it's really bad in the winter cause your toes feel like there freezing I take off the bottom cover under the steering wheel and usually shove my foot up under the dash to get it warm. it is one thing that honda really failed on
Old Nov 30, 2009 | 11:19 AM
woodwardba0526's Avatar
Default 2002 Civic ES1 Ex
My heat works great on my feet. It blows just as hard as it does coming from the normal vents.
Old Dec 2, 2009 | 02:06 AM
Thank you for the further input bomerman and woodwardba. I finally set the fan on high and the climate control unit on 'feet only' and went under the dash. With the fan on the highest setting, the air blows hard from the one vent kind of far to the front and on the inboard side of the driver's footwell. But the venting does not blow directly on either foot. I get some improvement closing the upper outboard vent in the dash. Like bomerman says, I am resigned that it is a bad design.
Old Dec 3, 2009 | 12:58 AM
DynastyRacer22's Avatar
yeah mines the same the heat doesnt blast all the way down to the foot well usually just let the car warm up normal and whenever it gets a lil hot i'll leave the vents to the foot area on
Old Dec 3, 2009 | 05:46 AM
Curiouz_G's Avatar
wear shoes and socks paul
Old Dec 3, 2009 | 08:44 AM
Good point. My 2003 Civic with the 1.7L engine does not warm up nearly as quickly as my 90s Civics did. (For the record, the coolant is topped off and the thermostat appears to be working fine. The heat out the upper vents is good; you just have to wait longer compared to the older Civics.)
Old Dec 4, 2009 | 01:23 PM
bomerman19's Avatar
Never!!!!!!!!!
singlecamslamed
Nov 20, 2016 07:56 AM
shesinmyroom
Jan 20, 2012 09:13 PM
NoEx00
Mar 8, 2007 07:31 PM
BauleyCivic
10
Apr 3, 2006 12:04 PM
AGPSuperstar
Apr 4, 2003 10:36 AM
