Quick Question befor work, b20z ecu, Researched.
Old Nov 27, 2009 | 08:46 AM
basiceg6's Avatar
Default Quick Question befor work, b20z ecu, Researched.
hey i dont know alot about ecu chipping but i did researched and got some info. just still a little confused on this one
would chipping a p28 ecu for b20z2 basemap be any different from a chipping a p75 with b20z2 basemap? because the p75 is alot cheaper
so i would get that instead
also would chipping a p75 make any difference? because i read that they are pretty similar
im just looking to maybe get a little more out of my stock b20z and want it to run correctly
thanks in advance
Old Nov 27, 2009 | 09:45 AM
92TypeR's Avatar
FSAE
Default Re: Quick Question befor work, b20z ecu, Researched.
Yes you can chip a P75 OBD1 ECU.
If you would like to add VTEC, more hardware must be added to the ECU board besides the typical 'chip kit'.
You can get more info on PGMFI.org
s032105k
Engine Management and Tuning
Mar 2, 2011 02:23 PM
volkracing99
Jan 17, 2002 01:06 PM
