parting out 1996 integra gsr 4dr
parting out a 1996 integra gsr 4dr, everything on the car is for sale!
drivers side engine mount $40
windshield air scoop $10
fuel pump $60
fuel sending unit $20
power window regulators $50 each
left drivers side rear door, right passenger rear door
oem drivers, passenger, rear glass, $40 each
rear window glass $130
5 speed obd2 ecu $175
dashboard $10, no wiring!
matching key set, ignition, front doors, trunk, rear seat lock, trunk cable lock, & 2 keys $100
drivers side, side view mirror $15
grab handle $2 each
driver side power window master switch $50
passenger side power window switch $10
power door lock switches $5 each
intermediate shaft $40
drivers side axle $40
cruise control unit $25
cruise control motor $25
abs control unit $25
srs unit $25
rear view mirror $5
rear bumper support $20
rear beam brace, Comes with Bolts, Will Fit, EG,EK,DC, Chassis $25
rear trans bracket $35
driver side turn signal lens $5
door panel $15 each passenger front, passenger rear, drivers
passenger front door molding $5
I will add more as I remove them from the car
volk racing group c 18x8.5 5x100 5x114.3 $500 firm
Please call me @ 213 210 8948. NO text messages! I will not respond to text messages.
motor $old
left headlight $old
right rear door $old
exhaust piping $old
cat converter $old
climate control $old
cat converter $old
dr side power window motor $old
dr side lower control arm $old
Oem nissin brake master cylinder & booster $old
rear door handles, pair $old
clutch cylinder including pedal $old
front calipers, including brake pads $old
trunk interior panels $old
power steering rack $old
drivers side bare door, no dents $old
driver side rear door, bare $old
taillight $old
rear bumper $old
rear disk brakes including brake pads, hand brake cables, hand brake, rubber brake lines, prop valve, misc bolts etc. (everything to complete a rear disk swap) $old
rear shocks including springs, $old
gsr cluster $old
ac fan $old
radiator fan $old
shift **** $old
sideskirt $old
oem strut bar $old
turn signal/headlight switch $old
oem header $old
front & rear seats, no rips, tears, or stains. $old
rear sway bar$old
oem steering wheel $old
gorilla lugnuts for aftermarket wheels $old
armrest, including cupholder $old
passenger rear door molding $old
5 speed gsr trans, including starter, no grinds, never raced, only has 133,147 miles $old
ac lines $old
trunk $old
a/c condenser $old
shift linkage $old
3 17 inch rims with 215/40 tires, two tires have 65% tread left $old
fuel pump $60
grab handle $2 each
srs unit $25
rear view mirror $5
motor $old
left headlight $old
exhaust piping $old
cat converter $old
cat converter $old
taillight $old
rear bumper $old
gsr cluster $old
ac fan $old
radiator fan $old
shift **** $old
sideskirt $old
oem strut bar $old
oem header $old
rear sway bar$old
ac lines $old
trunk $old
a/c condenser $old
shift linkage $old
...are they n good condition??
