4*114.3 Brake Discs?
Old Nov 27, 2009 | 05:00 AM
DanM2009's Avatar
Default 4*114.3 Brake Discs?
As suggested in the title I'm looking for brake discs for my 4 stud, 114.3 spacing hubs also the hubs are type r too. I've looked everywhere and i can't seem to find them. PLEASE HELP!.
Old Nov 27, 2009 | 05:30 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 4*114.3 Brake Discs?
You bought a non-standard hub setup without finding out whether any replacement brake rotors would fit? Good job!!!
Old Nov 27, 2009 | 05:49 AM
DanM2009's Avatar
hmmm yes, as in non-standard well i thought Integra 96 type r hubs i thought at least more than one would be made which i'm sure they were also replacement parts and aftermarket parts. So without your petty answers about something that isn't helping i wouldn't mind an answer.
Old Nov 27, 2009 | 06:34 AM
Dogginator's Avatar
Daisy... Daisy...
These are difficult to find in the US. Your 96 Spec ITR brake rotors and calipers are the same size as the non ITR Integras. You can upgrade the front brakes to USDM ITR calipers and use 92-96 Prelude VTEC 282mm rotors. The rears may require redrilled rotors.
Old Nov 27, 2009 | 07:55 AM
cheezthis's Avatar
Damn...be nice, Ken. My car is also a 4x114, but I'm in the process of converting it to 98-spec/usdm itr size. The rear will take some investigating though.
To the original poster, if you don't want to convert it, I know fastbrakes.com sells the rotors.
Old Nov 27, 2009 | 08:05 AM
Dogginator's Avatar
Daisy... Daisy...
Measure the center diameter and total rotor height of the rear. I think it is that same are a non-ITR. If that is the case, it can be redrilled to 4x114.3.
The normal rear rotor should be 239mm diameter, 9mm thick, 61mm center bore, and 48mm rotor height.
Old Nov 27, 2009 | 08:18 AM
cheezthis's Avatar
No more re-drills for me, I had that on the GSR. I read, via search on here, the following...
I used prelude vtec rotors with usdm 5lug front calipers and they were bolt ons, if you use jdm caliper brakets you will need to machine them. For the rears 92 accord rotors and 5lug type r calipers usdm or jdm will get you the same sized brakes front and rear as a 5 lug r but stay 4 lug, all bolt on. I dont think you will find the info about the rear anywere, I spent a few nights with many parts for that one.
Will see what what that works out to.
Old Nov 27, 2009 | 08:29 AM
Dogginator's Avatar
Daisy... Daisy...
I agree. Unfortunately, your rears may not leave a non redrilled option.
I have redrilled 92-96 Prelude VTEC rotors on the front of my GSR. They were selected because a 4x114.3 can be redrilled to 4x100 without hole overlap and the center bore was the correct 64 mm. The center bore is critical.
hsumark
Mar 10, 2009 01:50 AM
logg_frogg
Mar 8, 2008 02:58 PM
eltigre
Jun 21, 2006 04:27 PM
dip-set
Jul 28, 2004 10:54 AM
