screeching noise in second gear, starts from 6k - redline
it was a b.elt issue. thanks guys
Any ideas on what may be causing this to happen?
By screeching..do you mean grinding/scratching sound?? If so it may be a worn 2nd gear synchro assembly....The gear and sleeve may also be worn. If it is more of a high pitched screeching..you may have a worn or damaged needle bearing on 2nd gear..not common but anything is possible! Hope that helps!!
crazyhouse2011
33
Oct 14, 2014 04:40 PM
