96 civic running problems
Old Nov 26, 2009 | 10:18 AM
93shadowcivic's Avatar
Default 96 civic running problems
hey guys ive been working on my buddies 96 civic but the only problem we have now is when when you drive it and get on the gas from a stop it bogs down. . it is also throwing P1300 codes , we replaced cap rotor and wire (and made sure to mark where each one goes) ignition control mod, spark plugs, and it still has the same problem. it does have a cracked exhaust manifold right above the o2 sensor on top. he ordered a new header 4 it but would the cracked manifold cause the problem or would it be something else
Old Nov 26, 2009 | 11:03 AM
jdm inc's Avatar
Default Re: 96 civic running problems
have you checked the tps sensor?
Old Nov 26, 2009 | 11:30 AM
not yet how would i check that and does it come off of the throttle body?
the idle is kinda weird stays high and if you tap gas it will drop back to where it needs to be
Old Nov 27, 2009 | 11:42 AM
ok so we changed the tps and were still having the same problem and its still runnung rough any more ideas
Old Nov 27, 2009 | 11:58 AM
SpawnedCivic's Avatar
New User
What does P1300 reference again?
Old Nov 27, 2009 | 12:04 PM
random misfire/ manufacture ignition system prob
do the 96 civic have PCV's if so where would it be located and would that cause problems
Ahmed Hussein
Sep 7, 2017 09:30 AM
Civie129
Jul 29, 2013 01:14 PM
ATrain707
Dec 12, 2011 09:22 AM
rareturbobreed
Jul 20, 2011 01:57 PM
