with crv cams, 11.8:1 compression, and timing gears...
Old Sep 1, 2002 | 04:42 PM
infamousALLMTR's Avatar
Default with crv cams, 11.8:1 compression, and timing gears...
could this be potent.. I wont have my ls/vtec for another six months but I will throw my 12:1 comp pistons and all my bottom end goodies on my engine now.
Old Sep 1, 2002 | 06:04 PM
Default Re: with crv cams, 11.8:1 compression, and timing gears... (infamousRRH)
any one know any specs on these?
Old Sep 1, 2002 | 07:38 PM
anyone?
Old Sep 2, 2002 | 12:32 PM
InfamousRS's Avatar
you forgot to add the 86mm part mike.
Old Sep 2, 2002 | 03:38 PM
bikeboy80's Avatar
Default Re: with crv cams, 11.8:1 compression, and timing gears... (InfamousRS)
am i missing something?
Old Sep 2, 2002 | 05:47 PM
Default Re: with crv cams, 11.8:1 compression, and timing gears... (bikeboy80)
block is 86mm monster with 11.8:1 comp. (around there) I would like to know if I had the crv cams in my head if it would improver performance with this combo of high comp and slightly better cams tweeked with cam gears.
Old Sep 2, 2002 | 08:07 PM
bikeboy80's Avatar
as far as i know the crv cams and ls cams are almost identical, imo i dont think it would do too much, i am assuming that you are using ls cams now?
Old Sep 2, 2002 | 08:25 PM
90accord1's Avatar
you resleeved that beast or bored it to 86mm? damn thats huge...
Old Sep 2, 2002 | 11:20 PM
InfamousRS's Avatar
Default Re: with crv cams, 11.8:1 compression, and timing gears... (90accord1)
Oh, he just took it to the local yocal machine shop and they said it would be fine to take the stock sleeves to 86, so he did it. You should see it!!!! Its HUGE!!!!
Old Sep 3, 2002 | 09:31 AM
what kind of cam should I run for now in about 6 months I should be LS/(monster)/vtec. so in the meantime for better performance what does anyone recommend?
Old Sep 15, 2002 | 08:12 AM
TimoneX's Avatar
New User
86mm with stock sleeves? Seems like they'd be substantially weakened. I'd try to strengthen the tops of the cylinder walls prior to doing anything stressful with that block.
threehonda
K Series
Dec 20, 2009 06:37 PM
0c00l
Jan 3, 2008 11:43 AM
jmoney45
Dec 9, 2007 11:58 AM
revteglsv
Oct 11, 2005 06:28 PM
MugenGTR
Aug 31, 2002 10:51 AM
