Need help with rear disk conversion 97 hb
I purchased a rear disk conversion for my 97 HB I forgot to ask what car it came off of now before I out it on I'd like to buy it break pads, rotors and lines but I'm not sure how to check to see what car it came off of....... I purchased the breaks from jdmcarboy its complete with lines and everything.... My question is what's the most common swap for this? if to guess what's would it be and if there's a way to check..... jdmcarboy said its a direct bolt on no mod needed.....
Thanks
Thanks
Just order pads for any '88 - '00 civic with rear discs or '90 - '01 Integra (all except type R) they all use the same rear pads.
Check for numbers cast into the trailing arms/rear spindles
Or maybe even some markings from jdmcarboy or whatever shop
Sometimes they write on them to identify their parts
SK7 is DA 90-93 integra
ST7 is DC 94-97 integra thats off the top of my head
Jues guessing but i think em1 is s03 cuz all the other si parts ive bought from honda are S03
But basically if its not SK7 then you got dc or em1 which are interchangeable
Ther're all the same except the RS and the SI dont have abs but you can cut that off
I couldnt find the writing on the cast there where some writing in the caliper but that only said 7clp 13s idk if that means something.........
Thanks I will do..... Hopefully I can figure this out...... So to recap 90-93 teg rear brakes are completly diffrent from 94-01 teg? Civic 88-00 same as 94-01 teg?
Ok there was some confusion goin on but i gt part numbers
ST7-81910F RR caliper 2000 integra
43022-SR2-030. Pad set 2000 integra
And guess what numbers is cast on them..... 7CLP-13S
So ask for 2000 integra pads
Awesome..... So this means the rotors and lines should also be for 00 integra..... This should be a direct bolt on right? So buying the same lines shouldn't affect installation
eltigre
May 16, 2006 04:49 PM
Corran
Jan 2, 2004 07:55 AM
