strange clunk from passenger side
on the passenger side, i hear a strange CLUNK noise, coming from the suspension or axle when i begin to accelerate and let off the clutch. i'm letting off the clutch slowly and still it makes that strange sound. i checked underneath and everything is tightened down so i doubt its anything loose. i'm guessing the axle might be screwed up, cause my buddy accidently knocked a bearing inside the axle boot loose, opened up the boot (fail), and put the bearing back in, installed the axle back inside, and now its making strange noises. it seems like its getting worse too, making sounds more often. so my question is, has anyone ever experienced this problem before, and if so was it the axle? or should i look somewhere else? is there anything i am overlooking that i need to take a peak at?
THANK YOU EVERYONE FOR YOUR HELP
95_Civic_4dr
Sep 6, 2009 02:38 PM
1 speedstar
Jul 18, 2003 03:58 PM
