What to do about LSD ????
Old Sep 1, 2002 | 03:59 PM
bfrank81's Avatar
Default What to do about LSD ????
Is there anyway that I can get an LSD with my stock D15A6 motor?
Thanks,
Old Sep 1, 2002 | 04:47 PM
wronghand's Avatar
Default Re: What to do about LSD ???? (bfrank81)
Quaife or Kaaz. Those are the two best options.
Old Sep 1, 2002 | 04:54 PM
bfrank81's Avatar
Default Re: What to do about LSD ???? (wronghand)
What are those? Do you have URLs for these?
Old Sep 1, 2002 | 04:58 PM
ThatRicerDaniel's Avatar
you can get a ZC LSD tranny.
Old Sep 1, 2002 | 05:05 PM
wronghand's Avatar
Here you go:
http://www.kaazusa.com/
http://www.quaifeusa.com/
And the ZC tranny with LSD is an option as well.
Old Sep 1, 2002 | 05:18 PM
bfrank81's Avatar
Here you go:
Does anyone have these?
Which one is better?
Thanks....
Old Sep 1, 2002 | 05:28 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
not to be a pisser mate, but try to do a search, here and on the WORLD'S GREATEST SEARCH ENGINE
there is a sea of info on LSD units. more than kaaz or quaife, BTW
stan
Old Sep 1, 2002 | 05:29 PM
wronghand's Avatar
I know MistaBone has the Kaaz and breaka_1_9 uses the quaife. You may want to IM those guys and get their thoughts on it. I have a ZC with LSD, it just isn't installed yet.
Old Sep 1, 2002 | 06:27 PM
Blown90hatcH's Avatar
I prefer the Quaife. I prefer this for only one reason....been there when the car made too much power....one 2nd gear burnout....bye bye Kaaz. Installed Quaife and no problems since. I dunno though for low power, Kaaz may be suffice. But then you have to have some Kaaz juice.
[Modified by Blown90hatcH, 7:28 PM 9/1/2002]
Old Sep 1, 2002 | 06:31 PM
bfrank81's Avatar
Default Re: What to do about LSD ???? (Blown90hatcH)
Since I don't have the know how to do something like this what is the labor like on a project like this?
Old Sep 1, 2002 | 10:37 PM
philly-O's Avatar
optauto.com sells them
Old Sep 2, 2002 | 07:32 AM
It depends on if the tranny is out of the car. It takes me about 10 minutes to open the trans and get the diff out of the trans. Then you still have to get the speedo gear off of the old diff and have new bearings pressed on the LSD. Then you have to install the ring gear on the LSD. Install back in the casing....checking the shim clearance. So, I would say be preparred to pay for around 1-2hrs of labor.
Old Sep 2, 2002 | 10:13 AM
bfrank81's Avatar
Thats it 2 hours???
Doesn't sound to bad. Does anyone else have experience with this install??
Old Sep 2, 2002 | 10:42 AM
PhatOptimo's Avatar
2 hours if you know what your doing!
alot longer if you don't
Old Sep 2, 2002 | 01:28 PM
LoneStarCRX's Avatar
Is that for real? You have posted over 92,000 times?!!
Old Sep 2, 2002 | 08:50 PM
Default Re: What to do about LSD ???? (Phat_Optimo)
Definately true. For a first timer....plan on having your car down for alittle while....oh and buy a service manual.
Old Sep 2, 2002 | 09:04 PM
ijjz's Avatar
Default Re: What to do about LSD ???? (NitrousDreamz)
never thaught about that, zc is d series.. I keep thinking its not since its considered jdm.
Old Sep 3, 2002 | 04:03 AM
keithv's Avatar
Default Re: What to do about LSD ???? (ijjz)
i have the quaife LSD and love it. i haven't had any problems yet, but i still haven't auto-xed with it yet.
just one other thing. i have heard that the kaaz is the stronger of the 2 diffs. that is opposite of what blown90hatch posted...
Old Sep 3, 2002 | 04:14 AM
Tbone's Avatar
Default Re: What to do about LSD ???? (breaka_1_9)
Here's something to think about, when your comming around a corner and your inside wheel lifts off the ground with a quaife it will stop spining and try to go the opposite way like a open diff, a kaaz wil keep spinning the same way.
Old Sep 3, 2002 | 05:29 AM
bfrank81's Avatar
Default Re: What to do about LSD ???? (Tbone)
So which way is better?
I plan on paying my mechanic to do this if I decide to get it done.
Old Sep 3, 2002 | 06:08 AM
keithv's Avatar
its better to have the front wheels always spinning in the direction you are traveling and in the same direction.
so the kaaz in this aspect is better.
Old Sep 3, 2002 | 06:23 AM
-TJ's Avatar
-TJ
ZC LSD's aren't very plentyful anymore, so I wouldn't count on just picking one up just like that. Also, since they are clutch type and 10 years old they aren't likely to be in such good shape anymore. I've got a ZC LSD that I've had since '99 and it's ability to claw through corners is considerably diminished. I'm pulling it apart this winter to start the search for new clutches....so if anyone know's who or where to get them, please let me know.
Old Sep 3, 2002 | 08:51 AM
I am just stating from a drag racing launching experience. The Kaaz died and the Quaife has held.
Who on here can lift their front wheels off the ground in hard cornering.
Also, if you plan on drag racing, I would get the Kaaz up to a certain amount of power. Also, remember that you have to continually service the KAaz with their Juice.
Old Sep 3, 2002 | 05:02 PM
bfrank81's Avatar
I just want an LSD that is reliable. If i have to sacrifice a little performance for reliabilty then that is ok.
Old Sep 3, 2002 | 05:12 PM
Tbone's Avatar
Well I have a Kaaz and from what i have seen, it requires more maint' than a quaife. but i love mine. If you dont like to get your hands dirty then I would prob go with the quaife.
