d16 Driv-side Axle has 1/4in. gap
Old Nov 24, 2009 | 09:45 PM
Linked's Avatar
Default d16 Driv-side Axle has 1/4in. gap
should there be one? and if not, how can i get it back in? the ball joints are back in already and it doesnt just slide in
anybody got any idea
thanks all
Old Nov 24, 2009 | 10:01 PM
thumper64's Avatar
Default Re: d16 Driv-side Axle has 1/4in. gap
Grasp it with both hands, pull back and thrust forward. (No homo!) There should be a small gap between the outer diameter of the inner joint to the transmission, but the inner diameter of the joint should mate flush against the seal. If you try to start the car and it doesn't move, you'll get what I mean...
Otherwise, pop the lower ball joint. Watch this video, it's easy. http://www.youtube.com/watch?v=ISY8b...eature=related
Old Nov 24, 2009 | 10:30 PM
Linked's Avatar
i tried to knock it in with a heavy wrench but didnt seem like it was gonna go in, do i need to op the ball joint to try the option you suggested or is popping the balljoint a second option?
thanks again
Old Nov 24, 2009 | 10:37 PM
thumper64's Avatar
Try pushing it in as is, but if you can't, pull the lower ball joint and have someone hold it back a bit. You may end up having to unstake your axle nuts and pull them completely to fix this. Make sure the C shaped clip on the end is opening downwards, put a dab of grease on it to hold it centered and use some force. Don't be a wuss, it can take some force to get that shaft in.
Always make sure they're fully seated before putting the nuts on. My first time doing axles I had that problem, and always check now.
Old Nov 24, 2009 | 11:04 PM
Linked's Avatar
i cant break my axle nuts because i broke a craftsman breaker bar and dont have air tools
i can go break my ball joint and still mess with the axle though and i never noticed the c-clip on the axle, will try that out
Old Nov 24, 2009 | 11:29 PM
owneyboy's Avatar
had the same problem... not sure why if u get it fixed let me know...
chowderhead
Apr 29, 2017 04:24 PM
C_Rock77
Aug 27, 2008 11:19 AM
Ti Rider
10
Feb 3, 2007 04:18 PM
VisualAutoMotoring
Oct 11, 2003 04:08 PM
GruvyTune
Jul 22, 2002 10:01 AM
