crank pulley stuck on shaft
Old Nov 24, 2009 | 03:52 PM
bdiz's Avatar
Default crank pulley stuck on shaft
so i got the crank bolt out and pulled the woodruf key out too.. but the pulley itself won't slide off. it moves about 1/8 inch then gets stuck and i cant pull it off. i sprayed some wd40 on it then tried prying around with a screw driver, still no luck... any ideas to pull it off?
o and with the woodruf out, i can spin the pulley itself freely on the shaft, so i'm pretty sure its not rusted or anything
Old Nov 24, 2009 | 03:56 PM
kaiba's Avatar
Default Re: crank pulley stuck on shaft
You need pulley puller tool.
Old Nov 24, 2009 | 04:05 PM
bdiz's Avatar
will the engine tilt enough to fit a puller in there by only removing the driver side mounts?
Old Nov 24, 2009 | 04:35 PM
VPUPPY's Avatar
Check the A/C idler pulley. If it's mounting bolt is loose the pulley may be touching the crank pulley preventing it from sliding out.
Old Nov 24, 2009 | 04:43 PM
GagnarTheUnruly's Avatar
Mine popped right off.
Old Nov 24, 2009 | 09:49 PM
ek9dc2's Avatar
Use 2 prybars one one each side and work it from side to side
it has worked for me many times at the shop
Old Nov 24, 2009 | 09:55 PM
bdiz's Avatar
damn i think you might be right... i'm gonna feel like such a noob if this is the problem..
Old Nov 25, 2009 | 10:52 AM
thewrai6th's Avatar
Mine usually pops right off, but last time I had to do the prybar on each side back and forth trick.
Old Nov 25, 2009 | 12:07 PM
bdiz's Avatar
it WAS that damn ac pulley!!! can't believe i missed that...
thanks for the replies
Old Nov 25, 2009 | 02:05 PM
VPUPPY's Avatar
Hey NP bro. Happened to me a few years ago.
bseriescrxsi
Mar 31, 2008 12:11 PM
SuicideSlide
Oct 9, 2004 08:27 AM
94si94cx
Oct 19, 2003 10:36 AM
david90
Aug 15, 2003 01:15 PM
johnzm
Jun 17, 2002 07:19 PM
