GSR motor Build question
Old Nov 24, 2009 | 12:15 AM
EddieLe76's Avatar
Default GSR motor Build question
quick question:
with skunk2 pro series stage 2 cams, can i run type r valvetrain safely? or should i just go ahead and pick up aftermarket valvetrain?
thanks in advance!
Old Nov 24, 2009 | 12:20 AM
djviet2000's Avatar
Default Re: GSR motor Build question
you can run it safe with itr valvetrain but with those cams i would invest in the aftermarket just due that itr valvetrain can withstand up to 8500ish but i seen some aftermarket valvetrain handle 9000 or more.
Old Nov 24, 2009 | 03:34 PM
FRESHTEG's Avatar
go aftermarket
Old Nov 24, 2009 | 04:00 PM
GagnarTheUnruly's Avatar
I'd bet money that an ITR valve spring will bind on a SK2P2 cam.
Actually, I just confirmed it: max lift on an ITR spring is 11.5 mm and bind is at 11.7 mm. A Pro2 is way over that. Put in that cam with ITR springs and stock retainers, etc. and say bye-bye to your valvetrain. Do your homework and get the right stuff (Supertech or SK2 springs and retainers, perhaps).
Also, it's not so important whether the valvetrain can handle high revs, because what are you going to be doing at 9k anyways? As long as they can control the valves at reasonable operating speeds they'll be stiff enough for you. It's more important to make sure that the springs and retainers can handle the massive forces being imposed by the lifting motion of the cams, and that the springs can safely operate along their full range of travel.
Old Nov 24, 2009 | 08:49 PM
671darren's Avatar
x2! Unless you like valve float, and or piston to valve visitation, I would go with skunk2 COMPLETE valvetrain, mainly because they stand behind their products, and the parts are all built to work together. Testing their parts on their own vehicles also make me feel warm and fuzzy.
Old Nov 25, 2009 | 09:39 AM
EddieLe76's Avatar
thats exactly what i needed to know! thanks! i was thinkin just go ahead and run with aftermarket, but i had itr valvetrain sittin around so i figured if it would be 100% solid id just run with it, but oh well! thanks again
Old Nov 25, 2009 | 05:18 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
NO you cannot run those CAMS SAFELY with itr valvetrain!!!!
Those cams require s2 pro valvetrain or comparable off brand!
Good luck, some of the best cams out there, IMO!
Old Nov 25, 2009 | 08:01 PM
671darren's Avatar
If you do decide to use what you've got though, I wouldn't run it hard. The skunk2 stuff is proven, my build next month will definitely include their products.
Old Nov 25, 2009 | 11:35 PM
racebum's Avatar
if you decide to use ITR VT you should buy the skunk 1s not the 2s. also, if you're going after max power with the pro VT the pro1s or endyn bumpstix would be better money spent than the stage 2s
JayDMJ
Feb 8, 2016 09:03 AM
408EJ1
Mar 28, 2011 05:40 PM
Dc295kid
Jun 6, 2010 12:05 PM
7racer
Apr 18, 2010 06:55 PM
CTR94Joes
22
Jun 10, 2003 08:30 AM
