5 min crank pulley removal
Old Sep 1, 2002 | 02:08 PM
photonjedi808's Avatar
Default 5 min crank pulley removal
Up to now i've done all the work on my CRX myself. But when it came time to change timing belt I called a pro. This guy came to my house. At first he tried using an impact gun. But that didn't work. So he brought out a jack stand, 1/2" breaker bar, a long *** extension, and a wierd looking wrench with a bike chain looking thing on attached to it. He wrapped the chain around the crack pulley, lock it and wedged the wrench against the engine mount. Then he placed the extension on the jack stand he had next to car. Stood on the breaker bar and the crank pulley loosend up. Then he used the impact. The entire procedure probably took less than 5 minutes.
I asked him what was that thing he used and he said it's a plumber's pipe wrench. But it was modified with a long chain. He said it's available at any plumber's store. But you have to make your own chain for it.
I just thought I would share this because there's a lot of people who are having a hard time taking the pulley off.
Old Sep 1, 2002 | 02:49 PM
zcivic91's Avatar
Default Re: 5 min crank pulley removal (photonjedi808)
yup someitmes a impact wont even break it loose...when i had my zc motor put in..the mechanic needed the crank pully key from the old motor...he busted 3 17mm impact sockets and almost burnt up the gun...alil wd40 and 10 minutes later it broke loose..
Old Sep 1, 2002 | 03:23 PM
altoid's Avatar
Default Re: 5 min crank pulley removal (zcivic91)
a 15 inch strong arm (new) since it broke my old one, and a new 17mm socket, since it also broke my two old ones, and a 3 foot pipe worked for my zc pulley
Old Sep 1, 2002 | 05:15 PM
ED8DX's Avatar
Default Re: 5 min crank pulley removal (altoid)
I ended up using an 18" breaker bar and a ten foot electrical conduit pipe. I barely was able to fit it in the garage.
Old Sep 1, 2002 | 05:57 PM
USDM 4G VTEC's Avatar
Default Re: 5 min crank pulley removal (ED8DX)
use a forge steel socket, with a breaker bar and use the tube off a big car jack(the big long ones for like 5 tons) and use it to extend the breaker bar.... more power..... has worked for me before.....
Old Sep 1, 2002 | 06:19 PM
Mugen Dom's Avatar
Default Re: 5 min crank pulley removal (JDM EF9)
a lil bit of heat from a torch and an impact
Old Sep 1, 2002 | 07:13 PM
samiam's Avatar
175 psi of shop air and a snap-on IM5100 series impact gun w/ a short 17mm socket..
BLKFLSH
Apr 10, 2011 01:54 PM
jddwls
Sep 19, 2007 10:26 AM
lacking vtec
Mar 24, 2007 04:55 AM
EgSalad
22
Oct 7, 2005 05:03 PM
Lei Siew Long
Sep 11, 2001 11:39 AM
