Need help, compression lost in cylinder 2 and 3
I have a 95 LS which is bone stock. Before I start modding it I wanted to make sure that my car is running up to par. So I take it to a local shop and had them do a leak down test on my engine, in order to find out how much compression I had in each cylinder. cylinder 1 and 4 had 175 psi, but 2 and 3 had 150ish psi. The mechanic says I might need a valve job. Has anyone had this problem or ran in to? What do you guys think? Thanks for looking.
should be listed at the BC home page. the exhausts are app specific, so, if you order a 4dr exhaust you should be golden. very loud annoying exhaust though.
