Rattling/buzzing short shifter.Not heatshield.
Old Nov 23, 2009 | 07:10 PM
ILS_09's Avatar
Default Rattling/buzzing short shifter.Not heatshield.
Like the thread says, I am currently experiencing rattling/buzzing noise from my short shifter. Never had the problem when it was first install a year or so ago. It's really noticeable during certain mph especially around 70. I have to apply an upward pressure on the shifter for the noise to go away. No, it's not the heat shield because I check and double check and there is perfect clearance. I check the long bolt that goes through the bottom of the shifter and it seems tight. Motor mounts are good. What could be the problem?
Old Nov 23, 2009 | 09:38 PM
zc_eg6's Avatar
Default Re: Rattling/buzzing short shifter.Not heatshield.
i have the same problem, i've even tried switching shift **** but still the same buzzing sound....i'm also lost...any help guys?
Old Nov 23, 2009 | 09:56 PM
ILS_09's Avatar
bump
Old Nov 23, 2009 | 10:09 PM
karma28217's Avatar
If you have an aftermarket exhaust your shift linkage could be touching the pipe somewhere which would definitely cause a buzzing sound.
Old Nov 24, 2009 | 10:34 AM
ILS_09's Avatar
It's not touching anything. Exhaust system is completely stock. I guess I'll probably have to take the short shifter off and look it at.
Old Nov 24, 2009 | 06:46 PM
ILS_09's Avatar
bump
Old Nov 25, 2009 | 07:24 AM
ssbpb16's Avatar
it may not be touching while your checking the car but while your doing 70 im guessing your in 5th gear and the different location of the shift linkage could be comning into contact with your exhaust. if its a small rattle i would say it was your engine mounts being a bit stiff but im not too sure otherwise. id check for contact through all gears.
Old Nov 25, 2009 | 01:41 PM
ILS_09's Avatar
I'll take that into consideration when I jack it up and look at it.
Old Nov 25, 2009 | 03:23 PM
lsd96teg's Avatar
Shifter bushings, i had the same problem. I replaced them, it went away.
Old Nov 25, 2009 | 05:12 PM
josh-roy's Avatar
+1 for shifter bushings.
Shifter bushings, mine did the same thing when i was going a certain speed. Changed, problemo solved.. you can get ES bushings for like 20$.
Old Nov 25, 2009 | 05:35 PM
ILS_09's Avatar
Yeah I had a feeling it was pointing towards that.Any other possible suggestions?
Old Nov 25, 2009 | 07:43 PM
zc_eg6's Avatar
When i replace my short shifter, i also replace my bushings to es, and i had it all replace 2 months ago, when i did my tranny swap. I made sure everything was well lubed and bolted down tightly. I'm running stock exhaust with no heat shield. The problem didn't start right after my swap but 1 month later....so i don't know whats going on down there.
Old Nov 26, 2009 | 12:09 AM
Spec R's Avatar
use the rubber bushings that come at the bottom of the stock shifter. its the resonance from whatever other vibrations are coming from the car translating into the shifter like a tuning fork.
lemme guess, your short shifter has sealed/ball bearing cartridges at the bottom of it, right?
Old Nov 26, 2009 | 08:55 PM
ILS_09's Avatar
I do not know exactly to tell you the truth whether it has sealed/ball bearing cartridges at the bottom of it or not. All I know is that it looks the same as the stock shifter except the ball on the bottom is bigger than stock. Yes, I did use the same rubber bushings from stock ones to put on my short shifter when my bro install it for me. Last time I check when I jack the car up, the rubber bushing seemed kind of rip on the bottom so I don't really know if that's causing the vibration. I'm almost certain that it's the rubber bushing and hoping it's nothing else. I won't know for sure until I take it apart when I have time which is soon.
Old Nov 27, 2009 | 01:38 PM
ILS_09's Avatar
Update: Problem solved. All I did was just add a washer on the inside of the shift linkage where the metal ball and it comes into contact and the noise went away. Thanks for help guys.
alscrx
25
Feb 9, 2008 07:44 AM
jdm2k_si
16
May 15, 2004 04:52 PM
xaznx
Nov 1, 2002 10:12 AM
Understeer
Oct 13, 2002 10:39 PM
ActiveAero
Jun 29, 2001 03:08 PM
