..Need help with my 95 integra gsr..
Have a problem with my 95 gsr in my eg..nd have a code 12..for the EGR or the butter valve or whatever it's called..under the intake manifold there's spot to put a plug in..I'm guessin for that egr/butterfly valve...I'm running a stock 95 civic si harness with the p72 ecu..wondering how to wire that up to work..pics could really help or direct me to site that could help..thanks for help!
Did more research..there's a plug underNeath the intake mnifold it has the same plug has the vtec plug believe it's the green one..but there's 2 pins in the plug..and I found out one wire goes in to A17 and a 12v source..
I need to know which wire go to what..put together my own plug and wires..so when pluged in there's a left nd right wire which one goes to the ecu..nd which one goes to te 12v source?
Thanks for the help..
your best option would be to find a diagram off an acura parts dealer website..they will map out everything that is suppose to be on the motor.
you probably might not have to do anything as the harness is for a different motor..as long as it runs and your check engine light isn't on.
