Critique my build, b20/v
I initially built a ls/v that ended up making 201/137 but like everyone, always wanted a little more. I ended up changing up the bottom end. Here's what the motor consists of:
B16 head with PNP and slightly milled for flat surface
skunk2 pro springs and retainers
skunk2 pro 1's degreed in
440 injectors
Skunk2 pro intake mani
skunk2 68mm tb
sri with velocity stack and filter
84.5mm sleeved bottom end slightly decked for flat surface
Rs machine pistons
stock ls rods with arp rod bolts
acl standard bearings
hytech rep header
2.5" cutout after header
Car made 215/163 tuned on eCtune. This was on a very hot day. The more we let the motor cool, the more it slightly made. Im pretty sure it is capable of 220. I was thinking of changing the cams out to pro 2's to get a little more.
Let me know what you guys think.
440 injectors
skunk2 68mm tb
Rs machine pistons
hytech rep header
What was the bottom when you made 201/137?
Yes Pro2's would get you to 220, maybe even a bit more.
You may also want to think about an intake change, Performer X.
This is also my daily driver. Are the pro 2's ok on a daily? Also, I did not want to drive around with a loud exhaust, which is why i have the cutout setup. Im running a greddy sp2 daily and when i race, i open the 2.5" cutout. Makes a big difference in the power. Gave an improvement of 14whp and 10wtq on the old lsv setup.
I also thought about changing the IM. I know the performer x would put the power up top but didnt know if it would really make a big difference. I forgot to mention that i did portmatch the skunk IM to the tb.
damn that is a good gain for that cut out...i have a ?...if i have a full exhaust with test pipe would a cut out make any gains since i have no restriction?
Definately Pro2's.
I don't see how they can't be good for daily driving, they make much more power on the low cam, making 'daily' driving more enjoyable.
I've built and tuned a number of Pro-series cam'd motors to date. They all start, idle, warmup and drive exceptionally well. Your tuner will need to be patient with the idle settings and advanced tables for Pro-series cams.
EDIT - Just saw you have pro1's, did you tuner get them to idle and drive well? If so, Pro2's aren't that much more aggressive on the low cam.
It all depends on what kind of exhaust it is. The cutout basically is a testpipe but with a little dump on the size. When the cutout is closed, its a regular full exhaust with a testpipe and its still fun to drive but i definitely can feel the difference with the cutout open. I assume you also would get gains from a cutout, i dunno if they would be as good gains as i got but there should be some gain. Im still hesitant on the 3" exhaust thing. I feel the gains wouldnt be that much of a difference because i have a full 3" exhaust or a direct 2.5" dump.
Definately Pro2's.
Yes, the biggest difference will be on the high cam. The low cam is just slightly larger.
You should be able to set target idle in eCtune to 850 or 875 RPM. Keep the fueling just south of stoich, and make sure your moving idle and idle vs ECT are all in-line with your target idle value.
would love to see what you pulled out with the pro 2's. im putting together a b20v right now 85mm sleeved. some people told me to try boost but for my daily i dont want that hassle. my set up with be
b20b block
85mm bore darton or RS machine sleeved
micro-polished and balanced crank
eagle rods and arp rod bolts
cp 85mm 11.5:1 or 12:1 compression pistons maybe 12.5:1 but dont want to push it since ill be on pump gas 93 octane
golden eagle vtec conversion kit with a cometic 85mm head gasket
acl bearings
gsr or itr girdle
head will consist of
b16a head
very mild street port and polish
supertech valvetrain with flat valves
skunk2 pro 2's
victor x manifold with 68mm or 70mm tb port matched
and either hytech tri-y replica header or rmf narrow style header.
i will be keeping a/c in the car so that may cause me to lose a few horses. not too many i hope. motor will be going into my daily driven ek, its my work car.
b20b block
acl bearings
gsr or itr girdle
b16a head
skunk2 pro 2's
b20b block
acl bearings
gsr or itr girdle
b16a head
skunk2 pro 2's
b20b block
acl bearings
gsr or itr girdle
b16a head
skunk2 pro 2's
You should pull nice numbers. I have a/c in my car now also but it never stays working. Im close to just removing all of it. When i was at the dyno with the old ls/v setup, the ps and a/c belts flew off and i pulled 4whp more, lol. The a/c wasnt on so it was probably mostly from the ps system. Since that day, i have never put the belt back on, and i even removed the entire system.
I just installed the pro2's. The quick settings provided by skunk did not work and was causing a clearance issue, so I used the same cam settings as I had on the pro1s. The pro 1s were degreed in and believe it or not they were set to +5 in, +4 ex. I put it to this setting and it runs fine now, no clearance issues, I just find that camgear setting very weird.
Power is now good. nice. TQ is big.
Dont F-around this is a nice set up.
Bigger is not always bether !
you gonna gain 10Whp. spend 1500$ and Over ( exhaust, intake, )
If you really want more
Go for another bloc B20 85mm bore X 95
get a stroker kit... if really want to stay in B serie
180TQ 240Whp
180TQ 240Whp
-1 to 0 range for the intake, and +3 to +4 range for the exhaust is safe and close to what will make best power for Pro2's.
