Suspension & Brakes Theory, alignment, spring rates....
ASR subframe/w Beaks tie bar. Question
Old Nov 23, 2009 | 05:14 PM
Franco EM1's Avatar
Default ASR subframe/w Beaks tie bar. Question
2000 Si
Would I have any problems with installing both ASR subframe brace with Beaks lower tie bar, with my rear sway bar? If so what would i need?
I know i dont need both, but it looks good
Old Nov 23, 2009 | 10:48 PM
eklum's Avatar
Default Re: ASR subframe/w Beaks tie bar. Question
are you using a dual sway setup? thats what i did with the beaks /asr setup i ran lmk
Old Nov 23, 2009 | 11:39 PM
flatblack-h22's Avatar
longer bolt
Old Nov 24, 2009 | 08:27 AM
dstah's Avatar
Originally Posted by flatblack-h22
longer bolt
x2. here are the specs on the bolt sizes you'll need. metric hex bolts, grade 8.8 or stronger. 10mm x 1.25 x 110mm. correct me if i'm wrong. i couldn't find any metric sizes at homedepot or lowes. i ordered mine directly from boltdepot.com
Old Nov 24, 2009 | 09:18 AM
joezjdm4dr's Avatar
longer bolt
^yup thats right you will need longer bolts...i just used some head bolts i had laying around they were long enough.... and it woked great heres a pic...
Old Nov 24, 2009 | 02:37 PM
Franco EM1's Avatar
Would I have to get a 24mm sway bar also or can i use my 00 Si one? Im not sure wat mm is my stock one and can i use my stock endlinks?
What package do u suggest me to buy from passwordjdm.com or is there some were else i can get a good deal at lmk thanks guys
Old Dec 14, 2009 | 09:18 PM
langjairicer's Avatar
Same Problem...but for a 94 integra GSR..I think I will need a: Metric hex bolts, Metric standard bolts, Steel grade 10.9, 10mm x 1.5 x 110mm, according to my research. Am I correct? The factory size is 10x80..so I assume 110mm will suffice the length needed to thread all the way through?
Old Dec 14, 2009 | 09:21 PM
And you can't use your stock endlinks...I had to upgrade mine to aftermarket adjustable endlinks because a 24mm sway bar is not compatible with factory end links. Additionally...I think passwordjdm is a rip off especially with shipping. I usually order from assaultech.com and jhpusa.com. jhpusa has a good deal on subframe/sway bar combos etc.
Old Dec 14, 2009 | 10:14 PM
.Manny.'s Avatar
Touching My Member
there is no need for both pieces at the same time. It is redundant. ASR is enough. Save the money
96Formula6spd
Jun 9, 2011 05:13 PM
alec3369
Feb 9, 2008 09:21 AM
94b16coupe
Suspension & Brakes
Jan 4, 2008 05:22 AM
TheIntegraGuy
Suspension & Brakes
Apr 7, 2007 06:11 PM
GR_DC2
Oct 22, 2004 08:37 PM
