Thermostat issue
Old Nov 23, 2009 | 11:43 AM
Mario245's Avatar
Icon2 Thermostat issue
I have a JDM B16a with a GSR head and I was wondering what thermostat would I use? Unless all B series thermostats are interchangable.
I ask this because my temp gauge, no matter how long I let the car warm up (even in summer) would never rise above the cold mark.
Side note: would a bad thermostat cause a slight misfire? Plugs 2, 3, and 4 all have carbon on them while 1 is fine and I assumed it was because I'm running rich due to a bad thermostat?
Thanks.
Old Nov 23, 2009 | 01:19 PM
Mario245's Avatar
Default Re: Thermostat issue
Bump, want to add that I have replaced the cap, rotor, coil (lost the spring on the old one), plug wires and plugs (these are the new ones with carbon on them).
Old Nov 24, 2009 | 07:28 AM
Mario245's Avatar
bump
Old Nov 24, 2009 | 07:36 AM
dpetro1's Avatar
b-series thermostats are interchangeable. i dont think thats causing a misfire though.
Old Nov 24, 2009 | 08:19 AM
itsnotfast's Avatar
No way can a thermostat can cause a misfire. It sonunds like you definitely need a thermostat. Try putting a timing light on the car and make sure its timed right.
Old Nov 24, 2009 | 08:47 AM
Mario245's Avatar
I've tried timing it before but it idles above 1000 and sounds like it wants to die as soon as it goes below 900-1000 rpm (starts kicking and sputtering).
I've tried setting the idle speed with the screw, but like I said it doesn't want to go below 1000 or it sounds like it wants to just die.
Old Nov 24, 2009 | 08:48 AM
90Rexx's Avatar
thermostats are like 15 bucks... just put one in and go from there.... maybe your guage is sticking?
Old Nov 24, 2009 | 09:07 AM
Mario245's Avatar
Well the heater/temp gauge both worked back in Jan. then I noticed it kept taking longer and longer for it to rise, then the heater stopped blowing hot air.
Old Nov 24, 2009 | 09:22 AM
dpetro1's Avatar
thermostats fail on the open position all the time, effectively meaning you have no thermostat at all. so the car cant get to proper temp.
Old Nov 24, 2009 | 11:22 AM
Mario245's Avatar
I was planning on replacing it anyway just wanted a little clarification.
I just assumed that the silght misfire was coming from my cars fuel being too rich due to the car never warming up.
Old Nov 24, 2009 | 12:18 PM
EFbomb's Avatar
the car has 2 coolant temp sensors, one for the ecm, one for the gauge. both are in the head and should read hot if the thermostat is not opening.
I'd still replace the t-stat to be safe.
I would always recommend using OEM, i've cheaped and used the parts store "OEM replacement" one and still had an overheating issue until i bought a OEM t-stat and that fixed it.
when you replace the t-stat, double check all engine grounds and make sure they are good.
Good Luck
Old Nov 24, 2009 | 12:31 PM
dpetro1's Avatar
Good Luck
he isnt having a problem with the t-stat not opening, the problem is that it is stuck open not allowing the car to reach correct operating temp (underheating).
MrBigMac
Honda Civic (2001 - 2005)
May 15, 2016 04:25 PM
danno33
Jul 17, 2009 09:35 AM
PAsol_er
May 2, 2005 06:36 PM
efb16
Jan 15, 2005 07:06 AM
DragII
Aug 23, 2001 10:15 AM
