Need tips for replacing prop valve
Old Nov 23, 2009 | 11:39 AM
Bird333's Avatar
Default Need tips for replacing prop valve
This is on a 96 LX. It looks like a pain in the butt based on the location. I will be removing the MC and booster. Do I need to remove anything else? Did anybody use any teflon tape on the threads? Can anybody offer any tips for removing the prop valve?
Old Nov 23, 2009 | 09:46 PM
fastlane2's Avatar
Default Re: Need tips for replacing prop valve
Go to alldata at your local library and look up the diagram
Old Nov 24, 2009 | 09:56 AM
uberEFtuner's Avatar
Use PB Blaster. Also you need a 10mm flare nut wrench. Never use teflon tape! DO NOT USE WD40!
thedudefromjerz
Jan 21, 2009 08:59 PM
itr1244
Apr 10, 2006 07:39 AM
Civicr2gs5
May 5, 2004 03:18 PM
riceball777
Feb 6, 2004 06:05 AM
Andrew 825SM
Jun 19, 2003 02:09 PM
