braking problem.. plz help
Old Nov 23, 2009 | 10:28 AM
Civic-Kids's Avatar
Default braking problem.. plz help
step on brake pad hella deep to be able to stop... [not a honda]
anyone have this problem? is it rotor?? BRAKE STILL GOOD
Old Nov 23, 2009 | 10:33 AM
q.man06's Avatar
Default Re: braking problem.. plz help
Uh.. do you mean that the pedal travels further to start braking?
does it feel like it starts to brake, then to hold that same braking pressure the pedal travels further?
If so, it sounds like you're losing fluid pressure somewhere. This happened to me before and got worse quite quickly-- it was the brake master cylinder.
Old Nov 23, 2009 | 12:08 PM
Civic-Kids's Avatar
nope this problem is not master cylinder... i have master cylinder problem b4...
once it almost hit the floor it stop (like a normal stop. brake pad must be step on very deep for it to BRAKE.. on the red line IN PIX)
Old Nov 23, 2009 | 09:08 PM
danekmeier's Avatar
Well it could be a few things really. Caliper isnt working correctly or your brake lines have a major leak. I used to work at les Schwab and our normal things we look at is brake lines, caliper, then pad, then rotor, sometimes mc, brake booster. Those are the components i would look at it has to be one or more of those things.
Old Nov 23, 2009 | 09:14 PM
Former User's Avatar
Is the brake fluid low?
Have your tried bleeding the hydraulic system? If so, I would not discount the master cylinder as a culprit.
Old Nov 24, 2009 | 05:07 AM
300whpej's Avatar
def loosing pressure somewhere. start at the hub, checking pads/rotors/lines, then work your way to the mc...i doubt your brake booster has failed. 99% sure you have a bad line somewhere or a bad mc
fantasyboi_k
Feb 15, 2014 12:45 PM
hteg12
Jul 18, 2013 05:13 PM
USDM-EK4*
Apr 4, 2008 07:50 PM
superhatchbackbros
Jun 7, 2007 09:58 PM
Chubakon
Jul 29, 2004 08:56 AM
