Car "wanders" while driving
Old Nov 23, 2009 | 09:56 AM
zach1288's Avatar
Default Car "wanders" while driving
I have noticed lately that my car "wanders" alot while driving. I have to constantly move the wheel back and fourth to keep it in a straight line.
Old Nov 23, 2009 | 10:10 AM
king29's Avatar
Icon4 Re: Car "wanders" while driving
FL/FR control arm? have you checked for any damage?
Old Nov 23, 2009 | 10:35 AM
zcar4me's Avatar
Default Re: Car "wanders" while driving
Raise the front of the car securely on stands. Then forcefully move the wheel side to side, and up and down. It helps if you have a buddy underneath the wheel so they can spot any loose suspension joints.
If it's wandering, I'd say tie rod ends are first suspect.
And make sure the car is not going to move on the stands. Don't just use a jack.
Old Nov 23, 2009 | 10:38 AM
TypeRfit's Avatar
RESIDENT
Suspension can be the issue, lca bushings, tie rod ends, but it could also be something as simple as your tires, i've learned that certain tires i have had track alot more with the cracks in the road.
Old Nov 23, 2009 | 11:50 AM
300whpej's Avatar
when was your last alignment? if you replace your tie rods, you will need one anyway
Old Nov 23, 2009 | 12:35 PM
zach1288's Avatar
It was aligned a few months ago. I believe it was September.
Old Nov 23, 2009 | 12:40 PM
Pothole987's Avatar
easiest thing to do is check your air pressure in your tires. then go from there.
Old Nov 23, 2009 | 09:12 PM
danekmeier's Avatar
A fast way to do it is take it to to a place that does free checks they go through your whole car in 30 mins tops then poof you know your problem and then you can pinpoint your fix. les schwab for example.
4doorteggy
11
Dec 16, 2009 01:00 PM
nanagsr
Aug 20, 2009 12:34 PM
hybrid90
Suspension & Brakes
14
Feb 27, 2008 03:35 PM
vinuneuro
Jun 15, 2006 05:25 AM
jdmeg9
Jan 8, 2005 03:38 PM
