FS BUILT all motor b18c1 hytech , gsr , ITR , skunk2
fully built all motor gsr with tuned ecu $3500
3-4k miles all oem honda bearings were used
gsr block
cp 11.5 itr pistons 81.5mm bore
eagle rods
gsr 87.2mm crank
mugen headgasket
toda timingbelt
itr oil pump
itr waterpump
endyn ported p72 head
endyn springs and retainers
supertech flat valves
port matched skunk2 mani
port matched maxbore tb
jun3 cams
skunk2 gears
hytech header
rc 310's
tuned p28 on s200
tuned by mase @ stage6 in jacksonville
made 226whp through a world sport 2 catback
hytech 1.8L header in mint condition $1200
stock p05 ecu $75
stock p75 ecu $75
chipped p72 ecu $150
gsr throttle body with no tps $50
ls throttle body no tps $40
ls throttle body with tps $50
skunk2 camber kit for eg $75
itr rear sway bar with beaks style reinforcement $150
jdm itr gold shift linkage $150
3 eg ac condensers $50 a piece
stock gsr oem strut tower bar $50
gsr intake manifold obd1 $50
gsr intake manifold obd2 $50
ls longblock with bad bearing (did not spin just needs rebuild) $300
cut oem itr valvecover SOLD
gsr block
eagle rods
gsr 87.2mm crank
mugen headgasket
toda timingbelt
itr oil pump
itr waterpump
jun3 cams
skunk2 gears
hytech header
rc 310's
tuned p28 on s200
stock p05 ecu $75
stock p75 ecu $75
it is only 220 but it made it with a full world sport 2 catback exhaust and jun3's which are fairly small .... it was also on a dyno dynamics which read lower than dynojets , dyna packs
thanks guys
neophyte210
Feb 24, 2010 03:47 PM
