Transmission & Drivetrain Gearboxes, Differentials, Clutches
Swapping from LS to GSR FD
Old Nov 22, 2009 | 06:32 PM
SPOOLINmatt's Avatar
Default Swapping from LS to GSR FD
I have a GSR tranny with a Quaife and LS final Drive.
Do i have to change out the Quaife to a gsr quafe in order to run the GSR Final Drive?
Old Nov 22, 2009 | 07:49 PM
Aquafina's Avatar
Default Re: Swapping from LS to GSR FD
That or get a B16A2 FD.
Old Nov 23, 2009 | 04:32 AM
ah yes! thats the same FD isnt it, just the different bolt pattern?
Old Nov 23, 2009 | 08:21 AM
Honda Bull's Avatar
It's a 4.400:1 that will fit the diff that you have.
Old Nov 23, 2009 | 09:07 AM
will just the b16a ring gear work with the gsr countershaft since they are the same ratio? That would be more convenient.
Old Nov 23, 2009 | 09:08 AM
Aquafina's Avatar
It will work, but you'll have problems from not running a matched gear set.
Old Nov 23, 2009 | 09:12 AM
Ive mixed gsr gears from other gsr tranny's and such, i find that stuff hard to believe. This is a drag only car anyways, so the wear of that type is negligible.
Old Nov 23, 2009 | 10:24 AM
Aquafina's Avatar
I've had a lot of trannys come in with pitting and chipping from unmatched gears. A local had his trans rebuilt locally by a generic trans shop and brought it to me after a dozen or so passes (not a street car). Unmatched gears were pitted and starting to chip.
TeranceFL
Jul 12, 2013 06:37 AM
LS94tegra
Apr 16, 2010 10:08 PM
scspeed
Feb 2, 2010 09:19 PM
mr. vang
Mar 1, 2005 08:17 PM
Lscivichatch92
14
Oct 11, 2004 04:25 PM
