Radiator with thermostat built in, info needed
Old Nov 22, 2009 | 06:25 PM
0ne-Cam's Avatar
Default Radiator with thermostat built in, info needed
This is way off the honda/acura auto tech. I have a generator on my volvo semi truck, it heats the motor/tranny without the motor running. Other day the thermostat started mulfuctioning on the tbracket so I had to seal it off. Is there such a thing as a radiator (doesn't matter which size) with a thermostat built in? Searched but couldn't find anything
Old Nov 22, 2009 | 08:49 PM
The spongeness's Avatar
Default Re: Radiator with thermostat built in, info needed
Is there such a thing as an idiot? Hint: It's you
Old Nov 22, 2009 | 09:10 PM
thumper64's Avatar
STFU noob.
One-cam: There's an inline thermostat that maybe you could add:
http://www.wilsonmanifolds.com/shop/...t_detail&p=100
You could pull the thermostat housing off a D series motor and with a little modification, maybe that would work. PM me, I think I have one in a box of junk I can give away.
Then either keep your radiator you have or find one from a junkyard, or eBay...
Old Nov 22, 2009 | 10:38 PM
0ne-Cam's Avatar
Im assuming all your posts are like this?
Originally Posted by thumper64
STFU noob.
Thank you, that exactly what Ive wanted to find at the end of my search. PMed
ckorban
Aug 6, 2013 12:49 PM
milkwasabadidea
Jan 8, 2011 10:22 AM
SilverWarrior
Mar 8, 2008 09:05 PM
lude98SH
Aug 28, 2007 05:55 AM
missionaryrider
Jun 21, 2005 09:19 PM
