Gsr Calipers on Stock civic vx brakes
Would gsr calipers bolt right up to my stock vx brakes. Also if i do put the gsr calipers will my 13" lenso fit w/o any grinding down on parts?
unfortunately, the integra calipers won't bolt up to your civic VX knuckles. fastbrakes.com sells brackets and bigger rotors in order to use integra calipers, but 15" wheels are required. your 13" lenso fits will limit your choices for brake upgrdes.
* have you considered staying with your civic calipers? get blank rotors, good set of pads, s/s lines with fresh brake fluid
Yea i've been considering upgrading the pad, rotors, and lines. But i thought if the gsr calipers worked it'd be a nice little upgrade. Thanks
i dont think theres nothing you can do if you want to run 13" slicks....
ive seen 4 piston calipers from kvr that were for dx application using the original 9" brakes
TurboBumblBee
20
Jan 30, 2002 05:06 AM
